Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Material texture Settings |
| Print at Sep 20, 2026, 6:37:04 PM | View all posts in this thread on one page |
| Posted by KelvinUceta at Nov 27, 2022, 7:31:15 AM |
Material texture Settings Hi all, I'm having an issue each time I apply a texture on a object, to use a texture correctly I need to apply following setting: ![]() to get this: Am I doing something wrong? For the record, I use Blender to create my objects, I always reset "Scale" and "Rotation" before exporting to "Wavefront (.obj)". Actually it's not a real issue because I know how to work around but quite annoying. Thx ---------------------------------------- Dubito, ergo sum Mobo: ASUS TUF GAMING Z690-PLUS CPU: Core i9-12900K RAM: 32 GB DDR4 3200 Ghz GPU: MSI GeForce GTX 1660 SUPER 6G OS: Win 11 Pro 3D: SH3D 6.6.1 and Blender |
| Posted by Keet at Nov 27, 2022, 11:09:46 AM |
Re: Material texture Settings I suspect it has to do with the size and position of the image compared to the size of the surface it is applied to. Check this blog post and note the remark "in a way the captured image will match the size of the box side on which it will be applied". The settings you can make for textures are there to fix any positioning issues with an imported texture to make it fit the surface you apply it to. You can also adapt the image size itself, either when creating it or when you import it. You can also rotate the image before saving it, rotate the image with the settings, or rotate the box itself. (Each facet/surface has it's own direction in which a texture is placed.) ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by KelvinUceta at Nov 27, 2022, 4:26:58 PM |
Re: Material texture Settings Great Keet, I'll take a look! Grts, ---------------------------------------- Dubito, ergo sum Mobo: ASUS TUF GAMING Z690-PLUS CPU: Core i9-12900K RAM: 32 GB DDR4 3200 Ghz GPU: MSI GeForce GTX 1660 SUPER 6G OS: Win 11 Pro 3D: SH3D 6.6.1 and Blender |
Current timezone is GMT Sep 20, 2026, 6:37:04 PM |
