Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Place Posters (or pictures) in real size? |
| Print at Sep 15, 2026, 6:20:14 AM | |
| Posted by cmahnke at Nov 25, 2022, 4:10:35 PM |
Place Posters (or pictures) in real size? I'm currently planning an exhibition. One requirement to make the job easier would be to be able to add a (digitized) picture as a PDF (or JPEG) to a wall in its's size as indicated within the file (either as PDF page dimensions or in the size resulting in pixel multiplied by dpi / ppi). Is there a build-in way to archive this? If not can someone propose a way or give some hints about the feasibility on wring some Groovy script to use parts of the application to generate a obj file (or even a SH3F file) containing the right dimensions and the image as texture? |
| Posted by hansmex at Nov 28, 2022, 11:57:24 AM |
Re: Place Posters (or pictures) in real size? If you want to apply a picture to a wall, you can use JPG or PNG. When importing the picture set the height of your texture to the same height as the wall height. This way you won't have a vertical repeat of the image. If you want to apply a picture to a picture frame (e.g. painting or TV), you should prepare the picture as follows: - Make the relative dimensions of the image the same as those of the destination object. Example: if your TV screen is 16:9, your image should also be 16:9 - When importing, set height or width to the same value as the destination object to prevent repeating texture. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by cmahnke at Dec 20, 2022, 8:45:00 AM |
Re: Place Posters (or pictures) in real size? Thanks, but that seems to be much more overhead, since the necessary Informations are already part of the Image (or PDF) itself... I would argue that this is at leas a missing feature... I've created a Python script which solves the problem: https://github.com/cmahnke/oss-exhibition-too...cripts/generate-models.py |
| Posted by Daniels118 at Dec 20, 2022, 9:59:56 AM |
Re: Place Posters (or pictures) in real size? Maybe this could be useful: How to replace the picture of a frame |
| Posted by cmahnke at Dec 20, 2022, 10:06:02 AM |
Re: Place Posters (or pictures) in real size? Well, thanks for the hint. But I want to be able to just import for example a A0 sized poster as a PDF in the right dimensions (just setting hight above the ground). Not more, not less. The script helps with that by using Blender to create a OBJ file from a given JPEG or PDF with the right dimensions. This is a real advantage if you want to hang several dozend images or are doing walls completely in Inkscape. |
Current timezone is GMT Sep 15, 2026, 6:20:14 AM |
