Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Update 7.0.2 Not Working on Windows 11 |
| Print at Oct 14, 2026, 5:22:19 AM | View all posts in this thread on one page |
| Posted by rblaust at Oct 21, 2022, 5:03:36 AM |
Update 7.0.2 Not Working on Windows 11 I've been using Sweet Home 3D on Windows 11 for over a year with no issues. Then I installed the 7.0.2 update version and now when I try to launch the application I get the "could not create the java virtual machine..." message. I have tried uninstalling and re-installing JAVA, rebooted (multiple times), made sure Windows was up to date, increase the RAM for JAVA and nothing has helped. Please help. As of now the application is dead. |
| Posted by Puybaret at Oct 21, 2022, 12:09:18 PM |
Re: Update 7.0.2 Not Working on Windows 11 Sweet Home 3D installer comes with its own copy of Java, and you shouldn't have to install it on your side unless you need it for other purposes. But this shouldn't cause problems too. Did you install the 32 bit or 64 bit version (see Architecture option in installer)? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by rblaust at Oct 22, 2022, 1:45:46 AM |
Re: Update 7.0.2 Not Working on Windows 11 I installed the 64 bit version |
| Posted by Puybaret at Oct 22, 2022, 6:59:00 PM |
Re: Update 7.0.2 Not Working on Windows 11 Could you try to install the 32 bit version? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by rblaust at Oct 23, 2022, 3:03:10 PM |
Re: Update 7.0.2 Not Working on Windows 11 The 32 bit version worked! Thanks for your help. |
Current timezone is GMT Oct 14, 2026, 5:22:19 AM |
