Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Pb on focus with 22h2 |
| Print at Sep 15, 2026, 3:14:36 AM |
| Posted by Puybaret at Mar 3, 2023, 7:26:53 AM |
Re: Pb on focus with 22h2 And during these 30 seconds, are you able to select a material and change it? Said another way, does the whole program or only the 3D view seem to be blocked? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by bdfd at Mar 3, 2023, 10:54:43 AM |
Re: Pb on focus with 22h2 And during these 30 seconds, are you able to select a material and change it? Yes.Said another way, does the whole program or only the 3D view seem to be blocked? only the 3D view. . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Vinci68 at Mar 3, 2023, 12:08:33 PM |
Re: Pb on focus with 22h2 Maybe it has nothing to do with it but lately I had to uninstall and reinstall SH3D several times because the 3D display and the navigation between the tabs of the different floors of my house were blocked. (since 2 years I'm using SweetHome I never had any problem). I isolated the problem by re-installing the plugins one after the other and testing between each one. Everything worked fine until I reinstalled DimensionLines3D. And then everything froze again. So now I have to do without it (which I regret because it was very useful!!!) Maybe in your case this plugin brings you this problem ? I work under W10 x64 21H1 on an I5-8300 with 32Gb of ram and a NVidia GTX graphic card. |
| Posted by bdfd at Mar 3, 2023, 1:36:20 PM |
Re: Pb on focus with 22h2 It was an idea, but no ! I moved all plugin sh3p in other directory, and the problem goes on... Damned. . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by hanabi at Mar 4, 2023, 10:05:02 AM |
Re: Pb on focus with 22h2 Does your system use an Nvidia graphics driver? If so, try downgrading to an older version of the graphics driver. |
| Posted by Vinci68 at Mar 4, 2023, 5:29:41 PM |
Re: Pb on focus with 22h2 You are confused. The problems are with AMD Adrenaline drivers, not with NVidia drivers.. |
| Posted by hanabi at Mar 5, 2023, 12:50:28 AM |
Re: Pb on focus with 22h2 Ah yes that's right; I'm thinking of the display corruption problem, not slow 3D rendering. Apologies for the misdirection bdfd. When I had slow 3D rendering trouble previously it was because SH3D was using the CPU for rendering and not my computer's NVidia graphics card. The solution was to force SH3D to use the graphics card by adding an entry within NVidia Control Panel software (in the "Manage 3D settings") section. |
| Posted by bdfd at Mar 5, 2023, 7:38:03 AM |
Re: Pb on focus with 22h2 Hi, Well, it's not perfect but it's better ! Together, 7.1 and Nvidia panel reduce time. 1. for standard furniture : 3 to 5 sec 2. for imported furniture : 2 to 4 sec. We are on the way. . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by hanabi at Mar 5, 2023, 1:07:20 PM |
Re: Pb on focus with 22h2 Good to hear. It sounds like it had indeed switched to using the CPU for 3D for some reason. |
| Posted by MarioSambol at Jan 17, 2025, 11:50:28 PM |
Re: Pb on focus with 22h2 What kind of 3D object is it, how many polygons does it have? If it has a huge number of polygons, it is normal for it to load slowly. |
Current timezone is GMT Sep 15, 2026, 3:14:36 AM |
