Print at Oct 5, 2026, 10:46:47 PM View all posts in this thread on one page
Posted by decard at Sep 1, 2022, 2:52:00 PM
Overlaid Rooms
i mention that i can find no information in User Manual
simple question: how is the display order of the (floor) surface of different 'Rooms' determined when they overlap each other?
Posted by Puybaret at Sep 1, 2022, 3:04:12 PM
Re: Overlaid Rooms
Rooms are drawn in the order they were added.
Note that it doesn't give the same result in the plan and in the 3D view.
In the plan, a room is filled with a half transparent color or texture so you'll see other rooms below it (in the levels at the same elevation if any).
In the 3D view, a room floor will cut room floors below it.
Posted by decard at Sep 2, 2022, 6:41:19 AM
Re: Overlaid Rooms
hmmm. noted.
*** latest on top? any wy to reorder (other than deleting and redoing)? can different Levels be used?
*** 'below' meaning 'added after/later'?
cheers
don
Posted by Puybaret at Sep 2, 2022, 10:21:05 AM
Re: Overlaid Rooms
Lastest added on top (but with transparency in the plan).
To reorder a room you have to cut-paste it.
Only rooms in the levels at the same elevation are drawn (and it depends on which level you selected).
No, it means "added before".
Posted by decard at Sep 3, 2022, 5:58:03 AM
smile   Re: Overlaid Rooms
sorry. i mis-wrote.
