Print at Oct 6, 2026, 12:55:17 AM
Posted by decard at Aug 30, 2022, 8:33:45 AM
Dimensions - Appearance
can you change the appearance of the Dimension lines?
eg make it dashed or dots?
this would help make Dimensions much clearer visually and not confused with other plan solid lines
obviously, should be a selection option in Dimension Preferences
Posted by Puybaret at Aug 30, 2022, 2:13:27 PM
Re: Dimensions - Appearance
Dimension lines appearance can't be changed.
Posted by decard at Aug 30, 2022, 2:23:41 PM
noted. thank you.
hopefully i am giving you ideas for enhancements? :-)
Posted by Puybaret at Aug 30, 2022, 2:31:18 PM
I had the idea to allow a different color for dimension lines, not sure it will also allow the change you hoped.
Posted by decard at Sep 4, 2022, 3:13:49 PM
yet you already have this function in (somewhere that i cannot remember where i see) :-)
Posted by Puybaret at Sep 4, 2022, 6:58:07 PM
You won’t find this idea anywhere since I didn’t program it yet!
Posted by Keet at Sep 4, 2022, 8:31:30 PM
You probably saw it with the polylines, those you can change.
Posted by decard at Sep 6, 2022, 8:12:29 AM
that's it!! :-) thanks for reminder.
