Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Volume Plugin |
| Print at Sep 9, 2026, 11:02:48 PM |
| Posted by k005 at Aug 24, 2022, 11:53:35 AM |
Re: Volume Plugin I compiled it again. I copied it to the plugin folder. I ran sweethome3d. But it crashed... when I deleted the volumePlugin I created, it popped up. I'm making a mistake on a small point, but I haven't found it yet. |
| Posted by Puybaret at Aug 24, 2022, 12:21:22 PM |
Re: Volume Plugin A JAR file is actually just a ZIP file. Could you list here its content with a ZIP utility? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by k005 at Aug 24, 2022, 3:37:15 PM |
Re: Volume Plugin I am adding my work that caused the lock by archiving it. The compiled jar file is also included. https://www.dosya.tc/server38/u4bxxl/VolumePlugin.rar.html ***************************************************************** Actually, I just need an icon-shaped starter frame that is placed in the tools menu for now and added to the toolbar. like the frame I gave below. how should i run it from Sweet Home. I will develop it later. this will be the map to me... Thank you. ![]() |
| Posted by Puybaret at Aug 24, 2022, 4:18:49 PM |
Re: Volume Plugin Your plug-in is correct but you compiled it with a more recent version of Java. In the properties of your project, change the Compiler compliance level to 1.8. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by k005 at Aug 24, 2022, 4:30:57 PM |
Re: Volume Plugin Ok. Thank you very much. Worked. *** Can you send a sample project like in my second question? I can also go through the volumePlugin... but it has menu placement. There is no toolbar! |
| Posted by Puybaret at Aug 24, 2022, 7:39:54 PM |
Re: Volume Plugin You could use the method showInputDialog in JOptionPane class (see tutorial here). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 9, 2026, 11:02:48 PM |
