Print at Oct 6, 2026, 12:31:12 AM
Posted by GrahamI at Aug 23, 2022, 4:17:32 PM
Furniture Library Editor
How does one Install this feature on an MS Windows PC?
I just see a whole bunch of Java files and I know nothing of Java.
Regards Graham sad
Posted by Puybaret at Aug 23, 2022, 5:32:29 PM
Re: Furniture Library Editor
Java files???
The Furniture library editor is a JAR executable file. Install a JRE or a JDK then double-click on the JAR executable file to run it.
Posted by GrahamI at Aug 24, 2022, 10:56:54 AM
Thank you.
All is resolved now.
I now have to learn how to use it.
I want to create a Post and Rail Fence, often used in a rural environment here in Australia.
Regards Graham
Posted by Keet at Aug 24, 2022, 12:23:00 PM
You don't need the Furniture Library Editor to create new furniture. For your fence you could create a nice fence by combining multiple resized Box objects. Variations can be made by using stretched cylinder objects.
You should get the geo models from https://sourceforge.net/p/sweethome3d/d-models/299/ which are very useful for creating furniture details. For example to create different post tops. Or put a Sphere halfway in the end of a cylinder to get a nice rounded top.
Once you have all your parts combined you can export them to a single object which can be imported in the Furniture Library or just used as you created it.
The Furniture Library is mainly to group multiple furniture objects into a single Library for easy import or to create a collection of your custom made furniture. It's also important for adding and changing a few properties for objects that are specific for Sweethome3D and can't be added to a stand-alone object. You can, for example, change the cut-out made by windows, doors, and staircases. The Furniture Library allows to add these features.
Posted by GrahamI at Sep 7, 2022, 8:30:13 PM
Is there "How to Use" Guide for this?
Posted by GrahamI at Sep 8, 2022, 8:40:50 AM
Thank you Keet.
That is very helpful and much appreciated advice.
I'm learning heaps here.
My thanks to all for your help.
Regards Graham
Posted by GrahamI at Sep 9, 2022, 7:08:37 PM
What a GEM of advice that the was!
Now, I haven't created my Post and Rail Fence yet.
But, I've learned so much more.
One Step at a time Sweet Jesus is my attitude!
Regards Graham
Posted by Puybaret at Sep 9, 2022, 7:14:03 PM
You can find some explanations here.
