Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Deselecting |
| Print at Oct 5, 2026, 10:11:23 PM | View all posts in this thread on one page |
| Posted by decard at Aug 18, 2022, 9:03:13 PM |
Deselecting i cannot find a way to simply DESELECT an item ie so nothing is selected. ESC certainly does not work: although that would be the obvious. the problem of not being able to simply UNselect is that instead it selects something else, eg some 'Room', and then unintentional changes are made to whatever has been accidently selected what i have had to do, when i remember, is scroll all the way of the design, and then click Enter (btw, before you ask, Search in the Users Manual finds nothing) |
| Posted by Puybaret at Aug 18, 2022, 9:06:57 PM |
Re: Deselecting It looks like it's time for you to read the shortcuts guide. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by decard at Aug 20, 2022, 4:06:58 PM |
Re: Deselecting sureeee, except ... 1. why would a simple basic thing like Deselect need a 'Shortcut'? 2. why wouldn't a simple basic thing like Deselect be about the 2nd thing you would put in a Users Guide in Edit Section (right after Select)? 3. why wouldn't Esc be a standard Unselect? 4. Having read the Shortcuts THREE times, there is simply NO mention of Unselect. the closest i coud get was some mention of toggles. |
| Posted by Puybaret at Aug 20, 2022, 4:51:05 PM |
Re: Deselecting As Dorin says in his signature: A computer program does what you tell it to do, not what you want it to do. Said another way, I think it’s time for you to use Sweet Home 3D as it is. Most of its behavior was inspired from other software and I won’t change it just because you expected something else. If the provided documents doesn’t work for you, feel free to write your guide. If its quality is good, I’ll be pleased to reference it in Documents page. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by dorin at Aug 21, 2022, 11:02:31 AM |
Re: DeselectingWhen You want to deselect an already selected item, SHIFT+click on this item. Shift are used for multiple selection and act also as toggle. For this You have to put back a flower on my avatar ![]() ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Puybaret at Aug 21, 2022, 12:38:09 PM |
Re: Deselecting Note that selecting / unselecting the object(s) under the cursor is also proposed in the contextual menu of the plan and the 3D view where you'll right click. And if you want to unselect everything, you may simply click outside of any item in the plan. When You want to deselect an already selected item, SHIFT+click on this item. In the furniture list, unselecting one item is done with Ctrl + click (cmd + click under macOS).---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by decard at Aug 25, 2022, 2:41:37 PM |
Re: Deselecting Hi Dorin thanks for this information the obvious question remains - why is this simple fundamental info not in the User Guide and/or obvious easy place? SHIFT for multiple select is a standard, as is CTRL to selct/deselect individual item so why is SHIFT-Select not Select/Deselect all? and CTRIL+Select Deselect current one SHIFT for both multiple select AND for Deselect is both inconsistent and confusing but i thank you for this basic information |
| Posted by decard at Aug 25, 2022, 2:44:52 PM |
Re: Deselecting hi. i already knew that clicking outside the plan area would deselect. that was the only way i could find!!! but do you know how how time that wastes to move across your whole plan to outside. Over and over and over! for something as basic and as constant and as frequent as Deselecting!! |
| Posted by Puybaret at Aug 25, 2022, 10:43:59 PM |
Re: Deselecting You could also lock the base plan so if you click on an item which is not part the of base plan (i.e. walls, rooms, polylines, texts, dimension lines and the furniture qualified as part of base plan), it will unselect the selected item(s). By the way, I wonder what other drawing software you use to be so upset about the proposed ways to unselect in Sweet Home 3D, and why you need so much to unselect all. I never saw such a menu item in the software I used and Esc never unselected current selection in them too. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 5, 2026, 10:11:23 PM |
