Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Error exporting SVG |
| Print at Sep 24, 2026, 7:05:38 AM | |
| Posted by dkaparis at Aug 16, 2022, 5:32:15 PM |
Error exporting SVG Greetings, Using Sweet Home 3D 7.0.2 under Archlinux and OpenJDK Runtime Environment (build 11.0.16+8). When I select the Plan->Export to SVG Format command and specify file, I get the following dump on terminal: java.lang.NoClassDefFoundError: org/freehep/graphicsio/svg/SVGGraphics2DThe produced file is zero size. Could this be a packaging issue? Any ideas how to diagnose further? Thanks, Dimitri |
| Posted by Puybaret at Aug 16, 2022, 8:34:09 PM |
Re: Error exporting SVG This looks like a packaging issue. Use the official release available at Download page. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by dorin at Aug 17, 2022, 10:20:26 AM |
Re: Error exporting SVG I use official version (from download page) under linux (debian). Running SweetHome3D & SweetHome3D-Java3D-1_5_2 it's OK (produce the expected svg result). I receive the same error (in terminal & 0 size file) ONLY when I use nimbus. (-Dswing.defaultlaf=javax.swing.plaf.nimbus.NimbusLookAndFeel) Maybe is not the only one issue under this settings. With SweetHome3D-6.6 all work OK. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by dkaparis at Aug 17, 2022, 11:43:09 PM |
Re: Error exporting SVG This looks like a packaging issue. Use the official release available at Download page. When running the downloaded jnlp version on the same system with javaws, the SVG export works without error. I filed a bug report at https://bugs.archlinux.org/task/75632. |
Current timezone is GMT Sep 24, 2026, 7:05:38 AM |
