Print at Sep 24, 2026, 8:46:48 AM
Posted by decard at Aug 16, 2022, 11:47:19 AM
Missing Functions: How do i set a Dimension to an exact figure?
i see no way to set a Dimension to an exact figure without dragging and tryiong to get it exact - which can take forever
how do you just set it to an exact length?
Posted by Puybaret at Aug 16, 2022, 8:38:51 PM
Re: Missing Functions: How do i set a Dimension to an exact figure?
Press <enter> then type the length. Again it’s explained in the help!
Posted by decard at Aug 18, 2022, 8:53:13 PM
as i thought i previously replied, that option simply does not appear to work after trying several times - you do NOT appear to be able to enter any figure; and ignores the fact that easy simple and logical fix is to simply have field settings on edit
Posted by Puybaret at Aug 18, 2022, 9:00:51 PM
It's available only at Dimension lines creation time, and when the plan has the focus (bordered by a blue line).
Posted by decard at Aug 20, 2022, 4:21:47 PM
really? how helpful.
Posted by MarioSambol at Jan 21, 2025, 3:09:27 AM
Double click on dimension and manually enter the number you need.
