Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Missing Functions: Bulk Setting Changes |
| Print at Sep 24, 2026, 9:34:05 AM | |
| Posted by decard at Aug 16, 2022, 11:44:33 AM |
Missing Functions: Bulk Setting Changes i can find no way to do bulk/global setting changes eg 1. how do i change/set ALL my wall heights to the same value (w/o changing individually of course)? 2. how do i change/set ALL my Bookcases (for example) to the same height or width (w/o changing individually of course)? |
| Posted by Puybaret at Aug 16, 2022, 8:35:20 PM |
Re: Missing Functions: Bulk Setting Changes What about selecting all, then choosing the Modify menu item of your choice? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by decard at Aug 18, 2022, 8:50:18 PM |
Re: Missing Functions: Bulk Setting Changes thank you for your response the idea of "Selecting All" (and even to do that, you have to select first - the option is not active unless you do that) is not exactly intuitive! i see that that seems to give me Modify Walls and Modify Rooms. THERE IS NO MODIFY DIMENSIONS (unless i am blind) |
| Posted by Puybaret at Aug 18, 2022, 8:59:15 PM |
Re: Missing Functions: Bulk Setting Changes THERE IS NO MODIFY DIMENSIONS (unless i am blind) You're not blind, it doesn't exist. Maybe one day...---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 9:34:05 AM |
