Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Export_Too_Small |
| Print at Sep 10, 2026, 1:45:13 AM | |
| Posted by pencil at Aug 4, 2022, 11:33:48 PM |
Export_Too_Small When doing a print to PDF the result is really small. Even with a print_preview does the plan show as a small rectangle on the overall preview. The plan is a 24ft x 41ft plan. How can I export this to a readable image as a PDF? Link to images: https://postimg.cc/gallery/YtNNns2 or.. https://i.postimg.cc/vcGJjqcz/Sweet-Home-Print-Issue.png https://i.postimg.cc/CzJ3VG8V/Sweet-Home-Print-Issue-PDF.png |
| Posted by Puybaret at Aug 5, 2022, 8:51:12 AM |
Re: Export_Too_Small You may have placed some very small objects at the borders of your plan that you should remove (use Edit > Select all menu item and zoom out to find them easily). Or you created different levels, and one these levels is much larger than your home plan (maybe for the garden?). In that case, make the larger level unviewable to get a smaller print. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 10, 2026, 1:45:13 AM |
