Print at Sep 10, 2026, 1:45:12 AM
Posted by T_R at Aug 4, 2022, 8:44:16 AM
Need Pro-Help!
Hello Forum,
Im new here and I use this fantastic Software to "build" houses who are may been extinguished soon for privat documentation only ( may one day some kids like to see it). Righ now i re-create by photos a wodden house who sits in a demolish area of Whuhan, China.
Not a lot i can use out of the libary, must create a lot items by hand and i dont have 3-D software because of my poor laptop.
Right now i like to build a living room shelve as it is. (swwet 60`).
My problem is, it has round edges and i dont find half-cylinder to create this. I used normal cylinder and tryed to "cut" with invisible boxes, dosent work. Also the shelf has a square hole i tryed with invisibel box and service hatsch- bothe dosent create a hole in the cylinder.
Who can halp me with some advice? would like to publish picture of original and so-far creation and the house, but.. i dint know how. looks like it is a big task to display the own work here, please send your advice !
May i can send pictures by email?!
Thanks to all!
Laptop :ThinkPad 490, WIN11Pro, 64Bit, 8GBRam, 6T Harddrive
Never give Up!
Posted by sjb007 at Aug 5, 2022, 12:09:52 AM
Re: Need Pro-Help!
SweetHome3D is not a modelling tool. It is very difficult to model anything new unless it is very simple.
If your laptop can run SH3D, it can run Blender. some parts of blender are very hard on the computer. The kind of things you will want to model will not be hard for your laptop. So, my advice is: download, and do some tutorials on Blender.
This thread answers how to get your images displaying inside the forum using MediaFire: http://www.sweethome3d.com/support/forum/viewthread_thread,1886
Or you can post a link to an online image. I have posted shared Google Drive links before, that people can click on and view. You are in China, so it is not clear what image hosting services you are able to use.
Posted by T_R at Aug 5, 2022, 2:38:41 PM
Re: Need Pro-Help!
No Googel service works at all in China. And to create an account on chines platform you need a chinese ID. I dont have. the internet restrictions for expats are higher and higher.
Never give Up!
Posted by hansmex at Aug 5, 2022, 4:52:24 PM
Re: Need Pro-Help!
Maybe this works:
- draw very thin walls in the shape of your shelf, you can also make rounded corners
- set the walls to a height of a few centimetres, corresponding to the thickness of your shelf
- insert a room
- delete the walls, then export and import the room
- this should give you the desired shelf
Posted by Keet at Aug 5, 2022, 10:39:38 PM
Re: Need Pro-Help!
For the square hole in the shelf you can export a box with the size of the hole and import it as a staircase. This will cut the hole in the room you created after following what hansmex suggested. Then select only the room for export and it should keep the hole.
Posted by T_R at Aug 6, 2022, 8:32:33 AM
Re: Need Pro-Help!
@Hansmex
Wow! Vielen Dank! der Tipp ist überragend gut. Hat prima geklappt. Würde dir gerne ein Bild der ersten Lösung senden. oder vom Haus. ist ein sehr komplexes Ding da es ein Haus darstellt welches vor rund 100Jahren in China gebaut wurde. Ist mein Hobby. bin da nun 6 monate dran- und nicht fertig. Alle Informationen kommen von Fotos die ich gemacht hatte.
Never give Up!
Posted by hansmex at Aug 6, 2022, 10:12:08 AM
Re: Need Pro-Help!
Sende mir deine Photo und mit deine Genehmigung werde ich es hier publizieren.
Posted by T_R at Aug 6, 2022, 4:27:20 PM
Re: Need Pro-Help!
@Hansmex
Vielen Dank wede ich gleich machen- 1. mail ist raus
Never give Up!
Posted by hansmex at Aug 7, 2022, 11:46:12 AM
Re: Need Pro-Help!
Below you find two images T_R sent me for publication.
First a picture of the real stuff
And here is the same in SH3D
Posted by T_R at Aug 10, 2022, 9:38:10 AM
Re: Need Pro-Help!
Thank you Hansmex!
Never give Up!
Posted by hansmex at Aug 10, 2022, 12:55:47 PM
Re: Need Pro-Help!
And here is a picture T_R sent me of his roof with home-made tiles
(sorry for the large size of the image)
Posted by sjb007 at Aug 10, 2022, 3:36:57 PM
Re: Need Pro-Help!
@hansmex Have you made any of those images publicly viewable? I see a broken image icon on the forum, and trying to open the image in another tab results in a 400 response code (Bad request).
Posted by hansmex at Aug 10, 2022, 4:01:02 PM
Re: Need Pro-Help!
Sorry, I don't know how to do that...
Will look into it, and/or look for a different hosting service.
Posted by hansmex at Aug 10, 2022, 4:18:24 PM
Re: Need Pro-Help!
I can't find a way to show pictures here... Mediafire changed its interface.
Follow the links to see the images.
The kitchen from a photo
- https://www.mediafire.com/view/7vl83h8j0s12b0s/T_R_kitchen_original.png/file
The kitchen as an SH3D image
- https://www.mediafire.com/view/898htox9w965lw6/T_R_kitchen_in_SH3D.png/file
The home-made roof tiles on the new
- https://www.mediafire.com/view/h6c1rs2v1cbbzi9/T_R_old_house.png/file
Posted by T_R at Aug 10, 2022, 5:14:40 PM
Re: Need Pro-Help!
many thanks hansmex. i can see clear
Never give Up!
