Print at Oct 1, 2026, 8:40:00 PM View all posts in this thread on one page
Posted by joshuaanstey at Jul 29, 2022, 11:26:56 PM
FurnitureLibraryEditor (Import not working)
I'm a new user, so it could be user error.
I am trying to create a new library with obj files, but when I go to import furniture, no files (or folders) appear once I click into Desktop / Downloads / etc.
See image below. Am I missing something?
https://ibb.co/vkqVRNX
Best, Josh
MacBook Pro (16-inch, 2021) Apple M1 Max
Posted by Puybaret at Jul 30, 2022, 12:18:00 AM
Re: FurnitureLibraryEditor (Import not working)
Maybe something bound to macOS security which sometimes becomes quite a hell to manage.
You could try to drag and drop the files you want to import directly in the Editor window.
Posted by joshuaanstey at Aug 1, 2022, 7:14:43 AM
Thank you. That approach didn't take either. It did respond some when I did it by showing the "Importing furniture.." dialog for a brief second and then disappearing without the full process taking place.
I have JAVA 18 installed, if that helps. Also, I have access to a PC that I can use to fulfill my needs in the short term, so no worries if MAC is the issue.
Cheers!
Posted by Puybaret at Aug 1, 2022, 9:24:18 AM
Don’t use a Java version > 15, and prefer an Azul OpenJDK Java 15 runtime similar to the one used in Sweet Home 3D.
