Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Poor resolution issue |
| Print at Sep 9, 2026, 10:10:55 PM | View all posts in this thread on one page |
| Posted by yaduch74 at Jul 24, 2022, 4:32:33 PM |
Poor resolution issue Hello, Trying to print/export or whatever my plan, the result is pixelated (~1cm per pixel). I've got a well defined plan on my screen, but if I print it, export it to svg, or to png using the plugin (whatever resolution I put) all plan elements are aligned on a pixelized grid of approximately 1cm, each line has a minimum width of this pixel size. Once imported in inkscape, I can move with accuracy those big pixels, but the accuracy has already been lost. Tried the icon resolution: I actually got some well defined bath&co inside pixelated walls I'm tearing my hear out on this problem sine a few hours without any solution to render an accurate plan. |
| Posted by Puybaret at Jul 24, 2022, 9:38:34 PM |
Re: Poor resolution issue Use a full black color pattern for walls if this this is really a problem. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by MarioSambol at Jan 21, 2025, 3:16:31 AM |
Re: Poor resolution issue I have no problems exporting to SVG, opening with Adobe Illustrator and printing, everything is fine. The Print Screen plan works just as well, especially if the monitor is 4K resolution. |
Current timezone is GMT Sep 9, 2026, 10:10:55 PM |
