Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Trouble installing Furniture Editor |
| Print at Sep 20, 2026, 1:01:05 PM | View all posts in this thread on one page |
| Posted by cstaudt at Jul 19, 2022, 8:31:01 PM |
Trouble installing Furniture Editor I just installed the latest version of Java and downloaded the latest Furniture Editor (there are no previous versions of either installed). All instructions say to double-click on the JAR and Furniture Editor WILL open, but it does not. There's a brief flash of a window, so something's trying to happen, but the Editor won't open. Any ideas on how to fix this? |
| Posted by Puybaret at Jul 19, 2022, 8:39:22 PM |
Re: Trouble installing Furniture Editor Don't try with a Java version > 15 at the moment. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by cstaudt at Jul 20, 2022, 12:00:44 AM |
Re: Trouble installing Furniture Editor The Java Uninstall Tool says I have version 8 as the latest version. |
| Posted by Daniels118 at Jul 20, 2022, 9:31:21 AM |
Re: Trouble installing Furniture Editor Try to run it from the command line and post here the console output. Open a command prompt and type: java -version |
| Posted by cstaudt at Jul 20, 2022, 10:23:30 PM |
Re: Trouble installing Furniture Editor It lists the java version as 18.0.1.1. So I need to find an older version? The second command yielded an error: unable to access jarfile furnitureeditor.jar. (The location was c:\windows\system32.) |
| Posted by cstaudt at Jul 20, 2022, 10:40:02 PM |
Re: Trouble installing Furniture Editor I think I got it to open. I had to change the prompt to the directory where the JAR file is located and the different filename (FurnitureLibraryEditor-1.29.jar). Now, I expected it to be populated with the furniture that's already in SH3D, but it's empty. Since I'm using the Microsoft Store version, I have not idea where (or if) it's stored on my hard drive. How should I proceed? |
| Posted by Puybaret at Jul 20, 2022, 11:25:27 PM |
Re: Trouble installing Furniture Editor It’s an editor able to modify SH3F libraries, so you have to open the SH3F file you want to edit first, and by the way, you should quit Sweet Home 3D if you want to edit the SH3F files used by the program. To find the folder of a SH3F file used by Sweet Home 3D, click on it among the files listed in the Furniture libraries section of the Libraries in use pane. The latter pane is displayed by clicking on the Libraries... button shown at the bottom of Sweet Home 3D About dialog box. Note that if you modify one of the SH3F files provided with the Microsoft Store version, you should keep a copy of your modified file otherwise you might lose the modification at next update. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Keet at Jul 22, 2022, 8:39:35 AM |
Re: Trouble installing Furniture Editor and by the way, you should quit Sweet Home 3D if you want to edit the SH3F files used by the program. I have used the editor on many occasions while SweetHome3D was also running and never had problems. Probably because the SH3F files I was editing were not imported yet in SweetHome3D.Was this requirement mentioned anywhere? A check and warning when you open a SH3F file which is already in use by SweetHome3D is a good feature for the next version because many users will not know this. That is, if it's safe to edit SH3F files not imported in SweetHome3D yet. Otherwise a warning that SweetHome3D must be closed is needed. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Puybaret at Jul 22, 2022, 12:58:51 PM |
Re: Trouble installing Furniture Editor I think I mentioned it in the main thread about the Furniture Library Editor. Editing an installed SH3F file is possible if it's not write protected but it won't have any effect in Sweet Home 3D until you relaunch it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 20, 2026, 1:01:05 PM |
