Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Nice to have "Display in Separate Window" issue |
| Print at Sep 6, 2026, 6:10:52 AM | View all posts in this thread on one page |
| Posted by KelvinUceta at Jul 5, 2022, 7:27:49 AM |
Nice to have "Display in Separate Window" issue Hi all, I'm having a "nice to have" issue, the fact is that each time I open specific SH3D file I need to reselect "Display in Separate Window", in other SH3D files I just need to do it once. ![]() It's something I could live without but is there any config in the Home.xml file I could modify to achieve this? Thx in advance! Cheers from Belgium ---------------------------------------- Dubito, ergo sum Mobo: ASUS TUF GAMING Z690-PLUS CPU: Core i9-12900K RAM: 32 GB DDR4 3200 Ghz GPU: MSI GeForce GTX 1660 SUPER 6G OS: Win 11 Pro 3D: SH3D 6.6.1 and Blender |
| Posted by hansmex at Jul 5, 2022, 10:52:10 AM |
Re: Nice to have "Display in Separate Window" issue You have to leave enough space around the windows when using separate windows, otherwise SH3D will not show as intended. I solved this by putting an empty "template" on my desktop that I open when starting a new drawing. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by KelvinUceta at Jul 16, 2022, 8:04:51 AM |
Re: Nice to have "Display in Separate Window" issue Hi hansmex, OK I could understand that one, I'm working on 5 different projects but this happens on 1 of them, that's why I though that could be a kind of setting, somehow... The only difference between those project is the size, 4 of the projects are around 300 KB, the one having the "issue" is 100 MB big. Thanks very much for your time. ---------------------------------------- Dubito, ergo sum Mobo: ASUS TUF GAMING Z690-PLUS CPU: Core i9-12900K RAM: 32 GB DDR4 3200 Ghz GPU: MSI GeForce GTX 1660 SUPER 6G OS: Win 11 Pro 3D: SH3D 6.6.1 and Blender |
| Posted by Puybaret at Jul 16, 2022, 12:09:53 PM |
Re: Nice to have "Display in Separate Window" issue The program will move the detached window of the separated 3D view to another place as soon as this window isn't fully visible at screen. This avoids to place this window somewhere where you can't see it (and handle it), for example if you open your SH3D file on a computer with a smaller screen. But this is probably too severe, it shouldn't move this window if it's partly visible. I'll fix that in a future version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by KelvinUceta at Jul 17, 2022, 8:24:04 AM |
Re: Nice to have "Display in Separate Window" issue The program will move the detached window of the separated 3D view to another place as soon as this window isn't fully visible at screen. This avoids to place this window somewhere where you can't see it (and handle it), for example if you open your SH3D file on a computer with a smaller screen. But this is probably too severe, it shouldn't move this window if it's partly visible. I'll fix that in a future version. Hi Puybaret, As I said this is not a big deal or real issue but a nice to have. Great, thx very much for the explanation, Grts, Kelvin ---------------------------------------- Dubito, ergo sum Mobo: ASUS TUF GAMING Z690-PLUS CPU: Core i9-12900K RAM: 32 GB DDR4 3200 Ghz GPU: MSI GeForce GTX 1660 SUPER 6G OS: Win 11 Pro 3D: SH3D 6.6.1 and Blender |
| Posted by KelvinUceta at Jul 19, 2022, 7:36:57 AM |
Re: Nice to have "Display in Separate Window" issue Decreased the size of the separate window, issue solved! Great, thx ---------------------------------------- Dubito, ergo sum Mobo: ASUS TUF GAMING Z690-PLUS CPU: Core i9-12900K RAM: 32 GB DDR4 3200 Ghz GPU: MSI GeForce GTX 1660 SUPER 6G OS: Win 11 Pro 3D: SH3D 6.6.1 and Blender |
| Posted by Puybaret at Jul 31, 2022, 9:19:48 PM |
Re: Nice to have "Display in Separate Window" issue In version 7.0.2, the detached 3D view will be moved (or reattached to the main window at reopening) only if it occupied less than 10% of the screen, except under macOS where the system doesn't want that the program opens a partially visible window. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 6:10:52 AM |
