Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Sudden problem using SH3D on chromebook Linux - no menu |
| Print at Oct 14, 2026, 6:17:46 AM | View all posts in this thread on one page |
| Posted by Ditrovic at Jun 21, 2022, 2:45:37 PM |
Sudden problem using SH3D on chromebook Linux - no menu Hello My students use SH3D on a chromebook. I installed the Linux-environment and for more than a year, everything worked fine. It had some minor issues, but nothing problematic. Since a month, SH3D starts but the entire menu is empty and it can't be clicked on. The field with the 3D-rendering is completely back and also empty. 2 months ago, everything worked perfectly. I tried to install it on a new chromebook, same problem. Anyone with the same problem? Is there a workaround? Thank you Dieter. |
| Posted by Puybaret at Jun 21, 2022, 4:19:43 PM |
Re: Sudden problem using SH3D on chromebook Linux - no menu There have been no new release of Sweet Home 3D for months, so it might be an issue in the operating system or in the repository where you downloaded it from. Where did you get it? Note that except for the Online version, I even didn't think that Sweet Home 3D could work on a chromebook! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Ditrovic at Jun 21, 2022, 4:42:49 PM |
Re: Sudden problem using SH3D on chromebook Linux - no menu Thanks for your fast reply. I only used: sudo apt-get update sudo apt install sweethome3d There's a Linux-option in the chromebooks that you can enable. It's very basic, but it works. Unfortunately it's very difficult to find any information online of chromebooks with linux. I'm curious how long it will take before Google abandons the project. |
| Posted by Puybaret at Jun 22, 2022, 8:31:01 PM |
Re: Sudden problem using SH3D on chromebook Linux - no menu Would it be possible that you try the version available at Download page? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Ditrovic at Mar 24, 2023, 10:55:46 AM |
Re: Sudden problem using SH3D on chromebook Linux - no menu Thanks for the reply's. I solved it by installing Sweet Home 3D this way: sudo apt update sudo apt install flatpak flatpak install https://dl.flathub.org/repo/appstream/com.sweethome3d.Sweethome3d.flatpakref --user |
Current timezone is GMT Oct 14, 2026, 6:17:46 AM |
