Print at Sep 10, 2026, 1:53:29 AM
Posted by artemisclark at Jun 2, 2022, 4:47:20 AM
Change the wall thickness in the online version
I am using the online version.
All walls are automatically 3" wide, which is not realistic (wall studs 2x4 = 3.75" + drywall on each side, add 1" = 4.75". Outside walls are 2x6 etc.)
Is there a way to change the wall thickness in the online version?
Thank you!!!!
Posted by Puybaret at Jun 3, 2022, 12:39:09 AM
Re: Change the wall thickness in the online version
You can double click on a wall to change its thickness or select more walls and choose Modify walls in the contextual menu.
