Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Delete background image |
| Print at Sep 24, 2026, 8:14:54 AM | View all posts in this thread on one page |
| Posted by catalpa34 at Apr 17, 2022, 11:29:08 AM |
Delete background image I've been trying to solve this for some time and I've read all the posts here I can find. Every time I create a new level, it has a background image automatically. How do I stop this behaviour? |
| Posted by Puybaret at Apr 17, 2022, 2:13:01 PM |
Re: Delete background image A level uses the same background image as the previous level if they are at the same elevation. If you change its order with the arrows at the right of the levels table shown in the Level modification dialog, it won't display it anymore. You could also change its elevation adding a very small value like 0.001 cm. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by catalpa34 at Apr 18, 2022, 10:42:34 AM |
Re: Delete background image I'm actually thinking it's not a background image, but more like some sort of waterwark. I have two levels with a background image, which covers the watermark. I'f I hide the background image, then I can see the watermark. |
| Posted by Mike53 at Apr 18, 2022, 1:54:19 PM |
Re: Delete background image Could it be shadow lines of walls on other levels you are seeing is it? |
Current timezone is GMT Sep 24, 2026, 8:14:54 AM |
