Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: ZipException: invalid entry CRC on opening the sh3d file |
| Print at Sep 22, 2026, 1:43:30 AM |
| Posted by shellie222 at Apr 5, 2022, 6:26:21 PM |
ZipException: invalid entry CRC on opening the sh3d filecom.eteks.sweethome3d.model.RecorderException: Can't read home from /home/test/house.sh3d at com.eteks.sweethome3d.io.HomeFileRecorder.readHome(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController$29.call(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController$29.call(Unknown Source) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at com.eteks.sweethome3d.viewcontroller.ThreadedTaskController$1.run(Unknown Source) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) at java.base/java.lang.Thread.run(Thread.java:829) Caused by: java.util.zip.ZipException: invalid entry CRC (expected 0xfb8b804d but got 0x93c7f7bb) at java.base/java.util.zip.ZipInputStream.readEnd(ZipInputStream.java:410) at java.base/java.util.zip.ZipInputStream.read(ZipInputStream.java:199) at java.xml/com.sun.org.apache.xerces.internal.impl.XMLEntityManager$RewindableInputStream.read(XMLEntityManager.java:3062) at java.xml/com.sun.org.apache.xerces.internal.impl.io.UTF8Reader.read(UTF8Reader.java:303) at java.xml/com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.load(XMLEntityScanner.java:1699) at java.xml/com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.skipSpaces(XMLEntityScanner.java:1433) at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$TrailingMiscDriver.next(XMLDocumentScannerImpl.java:1374) at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:605)I guess my file is somehow broken - how can I fix it? I already tried each of the sweethome3d files in work directory, but neither of them worked. I can though unzip the file and inspect the xml it contains. Any chance to repair from there on? |
| Posted by Daniels118 at Apr 5, 2022, 6:47:42 PM |
Re: ZipException: invalid entry CRC on opening the sh3d file Maybe just few of the files contained in the sh3d archive are corrupted, but the program don't allow a partial loading. Try to unzip the sh3d file and zip it again using any zip program, then change the file extension from zip to sh3d. During unzip the program may also inform you about which files are corrupted, allowing for a deeper analysis. In any case don't try to alter the corrupted files, always work on a copy. |
| Posted by shellie222 at Apr 5, 2022, 7:28:29 PM |
Re: ZipException: invalid entry CRC on opening the sh3d filesame error on opening, different hashes though (which is not uncommon amongst different compressors) no errors during the process though btw. i did not update java/sh3d or anything |
| Posted by Daniels118 at Apr 5, 2022, 8:12:24 PM |
Re: ZipException: invalid entry CRC on opening the sh3d file Can you share your sh3d file? |
| Posted by shellie222 at Apr 6, 2022, 12:55:33 PM |
Re: ZipException: invalid entry CRC on opening the sh3d file sure: http://ix.io/3UrP |
| Posted by Puybaret at Apr 6, 2022, 1:21:58 PM |
Re: ZipException: invalid entry CRC on opening the sh3d file The file you proposed isn't a ZIP file, it doesn't even start by PK magic number. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Daniels118 at Apr 6, 2022, 1:23:26 PM |
Re: ZipException: invalid entry CRC on opening the sh3d file Is this the broken file or the one you repacked? 7zip does not show any CRC error and I can open it in SH3D without getting any error on screen nor in the console output. This could depend by a different configuration. I'm running SH3D 6.2a on OpenJDK 11.0.10 64 bit on Windows 10 Home. I have saved back your file using my SH3D installation, please check if it works: http://ix.io/3UrT |
| Posted by shellie222 at Apr 6, 2022, 1:49:05 PM |
Re: ZipException: invalid entry CRC on opening the sh3d file Puybaret: it does curl -s http://ix.io/3UrP|base64 -d|xxd|head -n1 Daniels118: the broken |
| Posted by shellie222 at Apr 6, 2022, 1:52:53 PM |
Re: ZipException: invalid entry CRC on opening the sh3d file it seems, I can not modify my post: i checked your file (9371de37fd1f74aba736459b2c7ca24b) - it does not work either (same error) what did you do though? |
| Posted by shellie222 at Apr 6, 2022, 1:54:44 PM |
Re: ZipException: invalid entry CRC on opening the sh3d file |
Current timezone is GMT Sep 22, 2026, 1:43:30 AM |
