Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: New Bedroom |
| Print at Oct 6, 2026, 4:08:59 AM |
| Posted by SARRAVAL at Apr 5, 2022, 8:51:50 AM |
Re: New Bedroom That must be it ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by SARRAVAL at Apr 6, 2022, 11:44:20 AM |
Re: New Bedroom I reworked the lights on the advice of SJB007 and the shines I only have the shadows to improve. ![]() ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by sjb007 at Apr 6, 2022, 4:18:00 PM |
Re: New BedroomWow! That looks a lot more realistic. It has darkened the room down quite a bit though. It could use a bit more indirect lighting (bounce light) to give it a bit lighter feel. Or is the overhead light fixture supposed to be on? If so, that would typically be a stronger light than the others. A small hint on the bedside lights which is personal preference. They usually have two bulbs in them, one each side. This makes the fan of light broader, i.e. \ | | /instead of \|/Last thing. Is the middle section of curtain/net meant to be a plastic sheet? The upper folds have a shine which makes me think of a plastic shower curtain. If it is supposed to be a fabric net, you should remove the shininess. |
| Posted by SARRAVAL at Apr 6, 2022, 5:10:07 PM |
Re: New Bedroom ok i fix it all ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by SARRAVAL at Apr 6, 2022, 6:25:31 PM |
Re: New Bedroom And here is the job! ![]() ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by sjb007 at Apr 6, 2022, 7:28:53 PM |
Re: New BedroomExcellent job. Although if I walked in a bedroom to find that indivdual waiting for me... I would do a 180 and start running. That is one creepy looking figure. Unless "Stepford Wives" is your thing... |
| Posted by SARRAVAL at Apr 7, 2022, 11:32:51 AM |
Re: New Bedroom Hope you like this person ![]() ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by sjb007 at Apr 7, 2022, 3:22:55 PM |
Re: New Bedroom Much better. If I squint it could even be Lucy Liu. ![]() |
Current timezone is GMT Oct 6, 2026, 4:08:59 AM |
