Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Installing Sweet Home 3D JS Online on my server |
| Print at Jul 12, 2026, 2:20:36 AM | |
| Posted by kingoftailor at Mar 24, 2022, 9:17:40 AM |
Re: Sweet Home 3D JS Online Hello, Very good job.Congratulations. I downloaded the source code 6.6.4. It also managed to build with ANT. The install folder has been created, including the Sweethome3D-6.6.4.jar. I want to run on my own windows server where I installed the Tomcat server. I know I would need a war file to run (I may not know). What else should I do to be able to integrate Sweethome3dJS into my website, which would be served by my own server? Thanks |
| Posted by kingoftailor at Mar 24, 2022, 11:24:02 AM |
Re: Sweet Home 3D JS Online I downloaded the sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4 There are SweetHome3D and SweetHome3DJS folders. I run ant at first o SweetHome3D. It creates the install folder with jar file. it is perfect. After this i run ant on SweetHome3DJS. I got 3 errors: [mkdir] Created dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\SweetHome3DJSweetExtension [javac] D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\build.xml:32: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds [javac] Compiling 4 source files to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\SweetHome3DJSweetExtension [javac] warning: [options] bootstrap class path not set in conjunction with -source 8 [javac] 1 warning [mkdir] Created dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\ts [mkdir] Created dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\js [java] INFO: JSweet transpiler version 3.2.0-SNAPSHOT (build date: 2021-07-28 14:35:21) [java] 2022-03-24 10:44:19.019 INFO JSweetCommandLineLauncher:682 - input dirs: [..\SweetHome3D\src, tools\JSweet\src] [java] 2022-03-24 10:44:19.019 INFO JSweetCommandLineLauncher:694 - classpath: null [java] 2022-03-24 10:44:19.019 INFO JSweetCommandLineLauncher:709 - included: [def.*, com/eteks/sweethome3d/model.*, com/eteks/sweethome3d/tools.*, com/eteks/sweethome3d/viewcontroller.*, com/eteks/sweethome3d/io.*] [java] 2022-03-24 10:44:19.019 INFO JSweetCommandLineLauncher:710 - excluded: [] [java] 2022-03-24 10:44:19.019 INFO JSweetCommandLineLauncher:715 - add sources from directory: ..\SweetHome3D\src [java] 2022-03-24 10:44:20.020 INFO JSweetCommandLineLauncher:715 - add sources from directory: tools\JSweet\src [java] 2022-03-24 10:44:20.020 INFO JSweetCommandLineLauncher:760 - ts output dir: tools\JSweet\build\ts [java] 2022-03-24 10:44:20.020 INFO JSweetCommandLineLauncher:767 - js output dir: tools\JSweet\build\js [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:423 - no configuration file found at D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\.\jsweetconfig.json [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:528 - creating transpiler version 3.2.0-SNAPSHOT (build date: 2021-07-28 14:35:21) [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:530 - current dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\. [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:531 - base directory: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\. [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:532 - working directory: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:533 - tsOut: tools\JSweet\build\ts - D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\ts [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:534 - jsOut: tools\JSweet\build\ts - D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\ts [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:535 - candyJsOut: tools\JSweet\build\js [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:536 - factory: com.eteks.sweethome3d.jsweet.SweetHome3DJSweetFactory@4e04a765 [java] 2022-03-24 10:44:20.020 INFO CandyProcessor:123 - candies processor classpath: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\.\jsweet_extension;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\bigjs-3.1.0-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-awtgeom-1.8.132-20200519.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-batik-svgpathparser-1.10.0-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-swingundo-1.8.132-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-core-6.3.1.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\SweetHome3DJSweetExtension;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3D\libtest\jnlp.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3D\libtest\AppleJavaExtensions.jar [java] 2022-03-24 10:44:20.020 INFO CandyProcessor:141 - extracted candies directory: tools\JSweet\build\js [java] 2022-03-24 10:44:20.020 INFO JSweetCommandLineLauncher:891 - definition input dirs: [] [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:561 - node version: 'node' is not recognized as an internal or external command, [java] 2022-03-24 10:44:20.020 ERROR ProcessUtil:466 - unexpected version token 'node' is not recognized as an internal or external command, / 4.4.0 [java] java.lang.NumberFormatException: For input string: "'node' is not recognized as an internal or external command," [java] at java.base/java.lang.NumberFormatException.forInputString(NumberFormatException.java:67) [java] at java.base/java.lang.Integer.parseInt(Integer.java:654) [java] at java.base/java.lang.Integer.parseInt(Integer.java:784) [java] at org.jsweet.transpiler.util.ProcessUtil.isVersionHighEnough(ProcessUtil.java:458) [java] at org.jsweet.transpiler.JSweetTranspiler.lambda$initNode$0(JSweetTranspiler.java:563) [java] at org.jsweet.transpiler.util.ProcessUtil$1.run(ProcessUtil.java:334) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:361) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:246) [java] at org.jsweet.transpiler.JSweetTranspiler.initNode(JSweetTranspiler.java:560) [java] at org.jsweet.transpiler.JSweetTranspiler.transpile(JSweetTranspiler.java:816) [java] at org.jsweet.JSweetCommandLineLauncher$JSweetTranspilationTask.run(JSweetCommandLineLauncher.java:897) [java] at org.jsweet.JSweetCommandLineLauncher.transpileWithArgs(JSweetCommandLineLauncher.java:272) [java] at org.jsweet.JSweetCommandLineLauncher.main(JSweetCommandLineLauncher.java:240) [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:561 - node version: operable program or batch file. [java] 2022-03-24 10:44:20.020 ERROR ProcessUtil:466 - unexpected version token operable program or batch file. / 4.4.0 [java] java.lang.NumberFormatException: For input string: "operable program or batch file" [java] at java.base/java.lang.NumberFormatException.forInputString(NumberFormatException.java:67) [java] at java.base/java.lang.Integer.parseInt(Integer.java:668) [java] at java.base/java.lang.Integer.parseInt(Integer.java:784) [java] at org.jsweet.transpiler.util.ProcessUtil.isVersionHighEnough(ProcessUtil.java:458) [java] at org.jsweet.transpiler.JSweetTranspiler.lambda$initNode$0(JSweetTranspiler.java:563) [java] at org.jsweet.transpiler.util.ProcessUtil$1.run(ProcessUtil.java:334) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:361) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:246) [java] at org.jsweet.transpiler.JSweetTranspiler.initNode(JSweetTranspiler.java:560) [java] at org.jsweet.transpiler.JSweetTranspiler.transpile(JSweetTranspiler.java:816) [java] at org.jsweet.JSweetCommandLineLauncher$JSweetTranspilationTask.run(JSweetCommandLineLauncher.java:897) [java] at org.jsweet.JSweetCommandLineLauncher.transpileWithArgs(JSweetCommandLineLauncher.java:272) [java] at org.jsweet.JSweetCommandLineLauncher.main(JSweetCommandLineLauncher.java:240) [java] ERROR: cannot find Node.js: install first and make sure that the 'node' command is in your execution path [java] 2022-03-24 10:44:20.020 ERROR ProcessUtil:351 - cannot find node.js [java] java.lang.RuntimeException: cannot find node.js [java] at org.jsweet.transpiler.JSweetTranspiler.lambda$initNode$1(JSweetTranspiler.java:574) [java] at org.jsweet.transpiler.util.ProcessUtil$1.run(ProcessUtil.java:347) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:361) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:246) [java] at org.jsweet.transpiler.JSweetTranspiler.initNode(JSweetTranspiler.java:560) [java] at org.jsweet.transpiler.JSweetTranspiler.transpile(JSweetTranspiler.java:816) [java] at org.jsweet.JSweetCommandLineLauncher$JSweetTranspilationTask.run(JSweetCommandLineLauncher.java:897) [java] at org.jsweet.JSweetCommandLineLauncher.transpileWithArgs(JSweetCommandLineLauncher.java:272) [java] at org.jsweet.JSweetCommandLineLauncher.main(JSweetCommandLineLauncher.java:240) [java] ERROR: cannot find Node.js: install first and make sure that the 'node' command is in your execution path [java] 2022-03-24 10:44:20.020 ERROR ProcessUtil:365 - cannot find node.js [java] java.lang.RuntimeException: cannot find node.js [java] at org.jsweet.transpiler.JSweetTranspiler.lambda$initNode$1(JSweetTranspiler.java:574) [java] at org.jsweet.transpiler.util.ProcessUtil$1.run(ProcessUtil.java:353) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:361) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:246) [java] at org.jsweet.transpiler.JSweetTranspiler.initNode(JSweetTranspiler.java:560) [java] at org.jsweet.transpiler.JSweetTranspiler.transpile(JSweetTranspiler.java:816) [java] at org.jsweet.JSweetCommandLineLauncher$JSweetTranspilationTask.run(JSweetCommandLineLauncher.java:897) [java] at org.jsweet.JSweetCommandLineLauncher.transpileWithArgs(JSweetCommandLineLauncher.java:272) [java] at org.jsweet.JSweetCommandLineLauncher.main(JSweetCommandLineLauncher.java:240) [java] ERROR: cannot find Node.js: install first and make sure that the 'node' command is in your execution path [java] 2022-03-24 10:44:20.020 ERROR JSweetTranspiler:818 - cannot find node.js [java] java.lang.RuntimeException: cannot find node.js [java] at org.jsweet.transpiler.JSweetTranspiler.lambda$initNode$1(JSweetTranspiler.java:574) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:367) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:246) [java] at org.jsweet.transpiler.JSweetTranspiler.initNode(JSweetTranspiler.java:560) [java] at org.jsweet.transpiler.JSweetTranspiler.transpile(JSweetTranspiler.java:816) [java] at org.jsweet.JSweetCommandLineLauncher$JSweetTranspilationTask.run(JSweetCommandLineLauncher.java:897) [java] at org.jsweet.JSweetCommandLineLauncher.transpileWithArgs(JSweetCommandLineLauncher.java:272) [java] at org.jsweet.JSweetCommandLineLauncher.main(JSweetCommandLineLauncher.java:240) [java] INFO: transpilation failed with 3 error(s) and 0 warning(s) I use jre1.8.0_321 and jdk1.8.0_321 and apache-ant-1.10.12 |
| Posted by Puybaret at Mar 24, 2022, 4:40:29 PM |
Re: Sweet Home 3D JS Online Be sure to install node.js 14.17 and use JDK 11 to build the last version of Sweet Home 3D JS. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by kingoftailor at Mar 25, 2022, 7:13:18 AM |
Re: Sweet Home 3D JS Online Thank you very much. The sweethome3d and sweethome3djs projects were also compiled. I searched a lot, but nowhere did I find information on what to install on tomcat on my own server. Currently, the html file contains things like sweethome api / readHome / ..., furnitureCatalogURLs: ... lib / resources / DefaultFurnitureCatalog.json, and so on. However, in the sweethome3djs project (which I had to rename from zip to war), there are only js files in the lib folder and there is even the default.sh3d file. There is no resources folder or /sweethome3d.css. Nor did I find any information on whether I should use version 6.6.4 in the html file differently than before. |
| Posted by Puybaret at Mar 25, 2022, 10:17:49 AM |
Re: Sweet Home 3D JS Online You should rather build the .war file file with applicationBuild Ant target, then deploy the .war file on Tomcat by placing it in its webapps folder. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by kingoftailor at Mar 25, 2022, 12:51:01 PM |
Re: Sweet Home 3D JS Online I think I did that, but the result is a zip file: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS>ant -buildfile build.xml Buildfile: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\build.xml viewerLibraries: transpiledLibraries: [mkdir] Created dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\SweetHome3DJSweetExtension [javac] D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\build.xml:32: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds [javac] Compiling 4 source files to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\SweetHome3DJSweetExtension [javac] warning: [options] bootstrap class path not set in conjunction with -source 8 [javac] 1 warning [mkdir] Created dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\ts [mkdir] Created dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\js [java] INFO: JSweet transpiler version 3.2.0-SNAPSHOT (build date: 2021-07-28 14:35:21) [java] 2022-03-25 12:38:58.058 INFO JSweetCommandLineLauncher:682 - input dirs: [..\SweetHome3D\src, tools\JSweet\src] [java] 2022-03-25 12:38:58.058 INFO JSweetCommandLineLauncher:694 - classpath: null [java] 2022-03-25 12:38:58.058 INFO JSweetCommandLineLauncher:709 - included: [def.*, com/eteks/sweethome3d/model.*, com/eteks/sweethome3d/tools.*, com/eteks/sweethome3d/viewcontroller.*, com/eteks/sweethome3d/io.*] [java] 2022-03-25 12:38:58.058 INFO JSweetCommandLineLauncher:710 - excluded: [] [java] 2022-03-25 12:38:58.058 INFO JSweetCommandLineLauncher:715 - add sources from directory: ..\SweetHome3D\src [java] 2022-03-25 12:39:00.000 INFO JSweetCommandLineLauncher:715 - add sources from directory: tools\JSweet\src [java] 2022-03-25 12:39:00.000 INFO JSweetCommandLineLauncher:760 - ts output dir: tools\JSweet\build\ts [java] 2022-03-25 12:39:00.000 INFO JSweetCommandLineLauncher:767 - js output dir: tools\JSweet\build\js [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:423 - no configuration file found at D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\.\jsweetconfig.json [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:528 - creating transpiler version 3.2.0-SNAPSHOT (build date: 2021-07-28 14:35:21) [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:530 - current dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\. [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:531 - base directory: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\. [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:532 - working directory: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:533 - tsOut: tools\JSweet\build\ts - D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\ts [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:534 - jsOut: tools\JSweet\build\ts - D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\ts [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:535 - candyJsOut: tools\JSweet\build\js [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:536 - factory: com.eteks.sweethome3d.jsweet.SweetHome3DJSweetFactory@525b461a [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:123 - candies processor classpath: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\.\jsweet_extension;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\bigjs-3.1.0-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-awtgeom-1.8.132-20200519.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-batik-svgpathparser-1.10.0-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-swingundo-1.8.132-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-core-6.3.1.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\SweetHome3DJSweetExtension;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3D\libtest\jnlp.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3D\libtest\AppleJavaExtensions.jar [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:141 - extracted candies directory: tools\JSweet\build\js [java] 2022-03-25 12:39:00.000 INFO JSweetCommandLineLauncher:891 - definition input dirs: [] [java] 2022-03-25 12:39:00.000 INFO JSweetTranspiler:561 - node version: v14.17.1 [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:226 - 6 candies found in classpath [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:168 - candies changed, processing candies: CandyStore=[(commons-lang3-3.9,t=1627482944000), (bigjs-3.1.0-20170726,t=1501064550000), (j4ts-awtgeom-1.8.132-20200519,t=1589870766000), (j4ts-batik-svgpathparser-1.10.0-20170726,t=1501061682000), (j4ts-swingundo-1.8.132-20170726,t=1501060798000), (jsweet-core-6.3.1,t=1609936488000)] [java] WARNING: An illegal reflective access operation has occurred [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:295 - extract candy: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies.jar javaOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\src\jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies tsDefOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\typings jsOutputDir=tools\JSweet\build\js\jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies [java] WARNING: Illegal reflective access by org.jsweet.transpiler.util.Util (file:/D:/SWEETHOME3D/sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4/SweetHome3DJS/tools/JSweet/lib/jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies.jar) to field com.sun.tools.javac.tree.JCTree.type [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:295 - extract candy: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\bigjs-3.1.0-20170726.jar javaOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\src\bigjs-3.1.0-20170726 tsDefOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\typings jsOutputDir=tools\JSweet\build\js\bigjs-3.1.0-20170726 [java] WARNING: Please consider reporting this to the maintainers of org.jsweet.transpiler.util.Util [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:295 - extract candy: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-awtgeom-1.8.132-20200519.jar javaOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\src\j4ts-awtgeom-1.8.132-20200519 tsDefOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\typings jsOutputDir=tools\JSweet\build\js\j4ts-awtgeom-1.8.132-20200519 [java] WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:295 - extract candy: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-batik-svgpathparser-1.10.0-20170726.jar javaOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\src\j4ts-batik-svgpathparser-1.10.0-20170726 tsDefOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\typings jsOutputDir=tools\JSweet\build\js\j4ts-batik-svgpathparser-1.10.0-20170726 [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:295 - extract candy: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-swingundo-1.8.132-20170726.jar javaOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\src\j4ts-swingundo-1.8.132-20170726 tsDefOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\typings jsOutputDir=tools\JSweet\build\js\j4ts-swingundo-1.8.132-20170726 [java] WARNING: All illegal access operations will be denied in a future release [java] 2022-03-25 12:39:00.000 INFO CandyProcessor:295 - extract candy: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-core-6.3.1.jar javaOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\src\jsweet-core-6.3.1 tsDefOutputDirectory=D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp\candies\typings jsOutputDir=tools\JSweet\build\js\jsweet-core-6.3.1 [java] 2022-03-25 12:39:01.001 INFO JavaCompilationComponents:122 - creating JavaCompiler task with options: JavaCompilerOptions: [--module-path, D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\.\jsweet_extension;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\bigjs-3.1.0-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-awtgeom-1.8.132-20200519.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-batik-svgpathparser-1.10.0-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-swingundo-1.8.132-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-core-6.3.1.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\SweetHome3DJSweetExtension;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3D\libtest\jnlp.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3D\libtest\AppleJavaExtensions.jar, -cp, D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\.\jsweet_extension;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\bigjs-3.1.0-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-awtgeom-1.8.132-20200519.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-batik-svgpathparser-1.10.0-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-swingundo-1.8.132-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-core-6.3.1.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\SweetHome3DJSweetExtension;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3D\libtest\jnlp.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3D\libtest\AppleJavaExtensions.jar, -Xlint:path, -encoding, ISO-8859-1] [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\AutoRecoveryManager.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\Base64.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\ContentDigestManager.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\ContentRecording.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\DamagedHomeIOException.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\DefaultHomeInputStream.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\DefaultHomeOutputStream.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\DefaultLibrary.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\DefaultPatternTexture.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\HomeContentContext.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\HomeFileRecorder.java... [java] 2022-03-25 12:39:09.009 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\HomeXMLHandler.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\ObjectXMLExporter.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\ResourceBundleTools.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\XMLWriter.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\AspectRatio.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\BackgroundImage.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Baseboard.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\CatalogItem.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\CatalogPieceOfFurniture.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\CatalogTexture.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\CollectionChangeSupport.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\CollectionEvent.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\CollectionListener.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Content.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\DoorOrWindow.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Elevatable.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\FurnitureCatalog.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\FurnitureCategory.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeApplication.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeDescriptor.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeMaterial.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeObject.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomePrint.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeRecorder.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeTexture.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\IllegalHomonymException.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\LengthUnit.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Library.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Light.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\LightSource.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\PatternsCatalog.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\PieceOfFurniture.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\RecorderException.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Sash.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Selectable.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\SelectionEvent.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\SelectionListener.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\TextStyle.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\TextureImage.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\TexturesCatalog.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\TexturesCategory.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Transformation.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\tools\ExtensionsClassLoader.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\tools\OperatingSystem.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\tools\URLContent.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\AbstractPhotoController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\BaseboardChoiceController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ContentManager.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\Controller.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\DialogView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ExportableView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\FurnitureCatalogController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\FurnitureView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\HelpController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\HelpView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\HomeController3D.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\HomeView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ImportedFurnitureWizardStepsView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\LocalizedUndoableEdit.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ModelMaterialsController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\Object3DFactory.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ObserverCameraController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\PlanView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\PrintPreviewController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\TextureChoiceController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\TextureChoiceView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ThreadedTaskController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ThreadedTaskView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\TransferableView.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\UserPreferencesController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\VideoController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\View.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ViewFactory.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ViewFactoryAdapter.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\WizardController.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\HomeXMLExporter.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\CatalogDoorOrWindow.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\CatalogLight.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\DefaultFurnitureCatalog.java... [java] 2022-03-25 12:39:10.010 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Camera.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Compass.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\DimensionLine.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeEnvironment.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Label.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Level.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Polyline.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Room.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Wall.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomePieceOfFurniture.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\DamagedHomeRecorderException.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\InterruptedRecorderException.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\NotEnoughSpaceRecorderException.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\UserPreferences.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\DefaultTexturesCatalog.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\HomeURLContent.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\tools\ResourceURLContent.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\tools\SimpleURLContent.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\tools\TemporaryURLContent.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\PhotoController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\PhotosController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\CompassController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\FurnitureController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\Home3DAttributesController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\HomeFurnitureController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\LabelController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\LevelController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\PageSetupController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\PolylineController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\RoomController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\WallController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\BackgroundImageWizardController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ImportedFurnitureWizardController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\ImportedTextureWizardController.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\ObserverCamera.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\Home.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeDoorOrWindow.java... [java] 2022-03-25 12:39:11.011 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeFurnitureGroup.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\model\HomeLight.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\DefaultUserPreferences.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\io\FileUserPreferences.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\HomeController.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1145 - scanning ..\SweetHome3D\src\com\eteks\sweethome3d\viewcontroller\PlanController.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1170 - creating bundle file: tools\JSweet\build\ts\bundle.ts [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1227 - created tools\JSweet\build\ts\bundle.ts [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1145 - scanning tools\JSweet\src\def\sweethome3d\Core.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1145 - scanning tools\JSweet\src\def\sweethome3d\SAXParser.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1145 - scanning tools\JSweet\src\def\sweethome3d\Scene3D.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1145 - scanning tools\JSweet\src\def\sweethome3d\SweetHome3D.java... [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1170 - creating bundle file: tools\JSweet\build\ts\bundle.d.ts [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:1227 - created tools\JSweet\build\ts\bundle.d.ts [java] 2022-03-25 12:39:12.012 INFO JSweetTranspiler:865 - ts2js on org.jsweet.transpiler.TypeScript2JavaScriptWithTscTranspiler@7e3a2542 sourceFiles=137 [java] 2022-03-25 12:39:12.012 INFO TypeScript2JavaScriptWithTscTranspiler:84 - launching tsc... [java] 2022-03-25 12:39:18.018 INFO JSweetTranspiler:1330 - js output file: tools\JSweet\build\js\bundle.js [java] 2022-03-25 12:39:18.018 INFO JSweetTranspiler:849 - transpilation process finished in 17693 ms [java] > java2ts: 11453.4937ms [java] > ts2js: 5906.115ms [java] [java] INFO: transpilation successfully completed with no errors and no warnings [move] Moving 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\lib\generated [move] Moving 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\lib\generated [move] Moving 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\lib\generated [delete] Deleting directory D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build viewerConcat: [delete] Deleting directory D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist [mkdir] Created dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist\build commonLibrariesDistribution: install-yuicompressor: [copy] Copying 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist [copy] Copying 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist [copy] Copying 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist [copy] Copying 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist [copy] Copying 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist [copy] Copying 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist [copy] Copying 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist viewerDistribution: [delete] Deleting directory D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\dist\build [echo] Javascript viewer files in dist ready for ftp viewerBuild: [mkdir] Created dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\install\viewer\SweetHome3DJSViewer-6.6.4\lib [copy] Copying 13 files to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\install\viewer\SweetHome3DJSViewer-6.6.4\lib [copy] Copying 1 file to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\install\viewer\SweetHome3DJSViewer-6.6.4 [zip] Building zip: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\install\SweetHome3DJSViewer-6.6.4.zip [delete] Deleting directory D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\install\viewer\SweetHome3DJSViewer-6.6.4 [echo] install/SweetHome3DJSViewer-6.6.4.zip ready BUILD SUCCESSFUL |
| Posted by Puybaret at Mar 25, 2022, 12:58:15 PM |
Re: Sweet Home 3D JS Online You didn’t build applicationBuild target but default viewerBuild target. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by kingoftailor at Mar 25, 2022, 2:40:34 PM |
Re: Sweet Home 3D JS Online Thank You very much. It works perfectly. I did n't know that I must set build target. I am c# developer. Now all files in the war file. I'll probably ask later. Thank you for your time. |
| Posted by kingoftailor at Mar 27, 2022, 12:43:31 PM |
Re: Sweet Home 3D JS Online I successfully installed the war file in tomcat server. Previously, the following script worked in html: <script>How to use version 6.6.4 from my own server (in html page)? Unfortunately, I didn't find a description of this anywhere. There is no emptyHome in the war file, only the default. Thank You. |
| Posted by renaudpawlak at Mar 28, 2022, 9:43:39 AM |
Re: Sweet Home 3D JS Online Well, you need to change the URLs to your own server and empty home file. You can create an empty home with the desktop version of SH3D for instance. The 'readHomeURL' parameter is the public URL of your empty home for your case, and you need to have the same base URL for the index.html and the home to avoid CORS issues. |
| Posted by kingoftailor at Mar 28, 2022, 8:27:10 PM |
Re: Sweet Home 3D JS Online What is the correct html for the new version? Later this works for me: <div id="progress"> <div id="progress-bar" style="width: 0%;"></div> </div> <div style="width:100%;height:100%;"> <div id="home-pane" style="width:100%;height:600px;position:absolute;top:75px;left:0"> <div id="home-pane-toolbar"></div> <canvas id="home-3D-view" style="display:none" tabIndex="1"></canvas> <div id="home-plan" style="background-color: #FFFFFF; color: #000000" tabIndex="2"></div> <div id="furniture-catalog"></div> </div> </div> |
| Posted by kingoftailor at Mar 29, 2022, 12:19:08 PM |
Re: Sweet Home 3D JS Online How can I set the drawing canvas to appear (full size) but not the 3d view? On earlier version this worked: #home-3D-view {The largest problem is that the buttons seems disabled: ![]() The 3. problem is that there are no right mouse context menu (sweethome online vs megveszLAK.hu test page) ![]() The test page html: <div style="width:100%;height:100%;">The JavaScript: <script>Thank You |
| Posted by Puybaret at Mar 29, 2022, 12:57:16 PM |
Re: Sweet Home 3D JS Online The CSS and HTML parts in the main page index.jsp changed a lot between versions 6.4 an 6.6, and you should probably add the changes carefully in your page. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by kingoftailor at Mar 30, 2022, 12:21:19 AM |
Re: Sweet Home 3D JS Online Thanks, I've already done it based on index.jsp. There are two things I haven't found a solution to. I was unable to resize the drawing surface and the furniture selector jumps too wide from the initial width. How can I set the width of the furniture selector? How can I hide/remove the 3d view? How can I hide/remove the furniture view? |
| Posted by kingoftailor at Mar 30, 2022, 11:19:58 AM |
Re: Sweet Home 3D JS Online I resolved to hide 3d view and furniture details view: #catalog-furniture-splitter {The right click menus work perfectly. |
| Posted by kingoftailor at Mar 30, 2022, 4:26:57 PM |
Re: Sweet Home 3D JS Online I figured it out. The furniture selector width was sette in the sh3d file (initial width). I created another emptyHome.sh3d with the windows version and the problem is resolved. |
| Posted by Puybaret at Mar 30, 2022, 5:35:26 PM |
Re: Sweet Home 3D JS Online Great that you could find out by yourself. Sweet Home 3D JS Online version uses CSS with well named styles for this purpose. Please share a link to the final version when it's ready. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by kingoftailor at Mar 30, 2022, 9:57:03 PM |
Re: Sweet Home 3D JS Online Your software is very cool. Here is the online version: https://megveszlak.hu/alaprajz-tervezo |
Current timezone is GMT Jul 12, 2026, 2:20:36 AM |
