Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Default furniture with install |
| Print at Aug 21, 2026, 2:59:16 PM | |
| Posted by otadmin at Mar 27, 2022, 9:10:03 AM |
Default furniture with install When I download Sweethome3D and run it some default furniture is available. Examples are "Box, Cylinder and Triangle". They do not show up in the Furniture-Editor nor can I find a .sh3f file containing those. Question: Where are the furniture-items found when SH is run without any .sh3f files? |
| Posted by Puybaret at Mar 27, 2022, 6:05:42 PM |
Re: Default furniture with install The default furniture is stored in the file Furniture.jar found in the lib subfolder of Sweet Home 3D installation folder. If need, you can remove it from there, open it with the Furniture Library Editor and save it in a SH3F file that you'll import in Sweet Home 3D. Note : the original post mentioned Furniture.zip file not Furniture.jar. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by otadmin at Mar 28, 2022, 11:16:30 AM |
Re: Default furniture with install Found and saved as .sh3f. But in both versions 6.4 and 6.6 the file is called furniture.jar. Opens with the editor no problem. |
| Posted by Puybaret at Mar 28, 2022, 12:00:57 PM |
Re: Default furniture with install Oups, sorry you're right the default furniture is stored in Furniture.jar not Furniture.zip. I should have double checked before answering. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 21, 2026, 2:59:16 PM |
