Print at Aug 21, 2026, 2:50:47 PM View all posts in this thread on one page
Posted by otadmin at Mar 27, 2022, 9:10:03 AM
Default furniture with install
When I download Sweethome3D and run it some default furniture is available. Examples are "Box, Cylinder and Triangle". They do not show up in the Furniture-Editor nor can I find a .sh3f file containing those.
Question: Where are the furniture-items found when SH is run without any .sh3f files?
Posted by Puybaret at Mar 27, 2022, 6:05:42 PM
Re: Default furniture with install
The default furniture is stored in the file Furniture.jar found in the lib subfolder of Sweet Home 3D installation folder. If need, you can remove it from there, open it with the Furniture Library Editor and save it in a SH3F file that you'll import in Sweet Home 3D.
Note : the original post mentioned Furniture.zip file not Furniture.jar.
Posted by otadmin at Mar 28, 2022, 11:16:30 AM
Found and saved as .sh3f. But in both versions 6.4 and 6.6 the file is called furniture.jar. Opens with the editor no problem.
Posted by Puybaret at Mar 28, 2022, 12:00:57 PM
Oups, sorry you're right the default furniture is stored in Furniture.jar not Furniture.zip. I should have double checked before answering.
