Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Imported Furniture Low Resolution in Plan View |
| Print at Sep 10, 2026, 9:00:16 PM | |
| Posted by mikedj at Mar 18, 2022, 6:12:04 PM |
Imported Furniture Low Resolution in Plan View When I import furniture created in Sketchup, it looks fine in SH3D 3D view, but is very pixelated in SH3D Plan View. My procedure is: - Create a solid model in Sketchup - Export the 3D model as either .dae or .kmz - Import furniture in SH3D - Drag the new furniture to the plan Sketchup model: SH3D 3D view: SH3D Plan view: Note that I added the texture in SH3D, which offers a little more visual clarity, but the issue exists even without the texture. I've also noticed a similar issue when using the "Generate 3D from rooms" plugin. Is there a setting or settings that affect import resolutions? Or settings for the plan view resolution? Thank you, Mike |
| Posted by Puybaret at Mar 18, 2022, 6:56:40 PM |
Re: Imported Furniture Low Resolution in Plan View See the Icon size setting in preferences pane. But keep in mind that it will apply to all icons and a higher value may require a lot of RAM to handle all icons. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mikedj at Mar 18, 2022, 7:31:54 PM |
Re: Imported Furniture Low Resolution in Plan View Perfect! Thank you! Mike |
Current timezone is GMT Sep 10, 2026, 9:00:16 PM |
