Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Create 4 Story Building |
| Print at Sep 20, 2026, 11:19:11 AM | |
| Posted by stef.salmon at Mar 4, 2022, 11:29:50 AM |
Create 4 Story Building Hi, Are there any videos on how to create a building with multiple floors. I'm not too worried about the inside of the building, but more interested in being able to create the look from outside, so it looks like a proper building with windows etc. It needs to look like the building that I'm choosing to model. Thanks in advance. |
| Posted by Puybaret at Mar 4, 2022, 1:11:19 PM |
Re: Create 4 Story Building Maybe you could look at the tip about designing large buildings. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by stef.salmon at Mar 7, 2022, 3:31:47 PM |
Re: Create 4 Story Building Hi, I checked out the 'Sweet Home Company' to see how it was put together. I noticed that each room/area had all it's furniture, doors etc, grouped together, so that when you moved a room all its equipment moved too. How is this done? Thanks. |
| Posted by Puybaret at Mar 7, 2022, 4:21:19 PM |
Re: Create 4 Story Building Use Furniture > Group menu item but it will group only furniture, not walls, rooms and dimension lines. Otherwise draw a selection rectangle to select all the objects you want to move (see also shortcuts here). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 20, 2026, 11:19:11 AM |
