Print at Sep 26, 2026, 4:39:02 PM
Posted by Pitouille at Nov 11, 2009, 9:07:46 AM
Text menus are blank/white
Hello I installed version 2.1 on my home computer ( because it was working very fine at work) the program starts normally and I have all the menus and the buttons, but if I click on 'file' for example on the text menu bar, it rolls down a white menu, nothing inside. The functions are appearing and disaprearing if I pass the cursor trough the menu, but it remains blank if I dont move.
If I use the functions they work, but it is quit embarassing to have all the menu content white.
Anyone evere recorded the same problem ?
Posted by Puybaret at Nov 11, 2009, 12:07:09 PM
Re: Text menus are blank/white
I never heard about this problem.
On what system are your running Sweet Home 3D?
What Java version do you use (see Sweet Home 3D About dialog)?
Posted by Pitouille at Nov 12, 2009, 11:30:14 AM
I will try to make a snapshot of the screen to let you figure out. I am on a standard win XP computer, I am at work for the moment and the computer is at home, I don't know my adobe version sad but I will check it tonight and let you know
THX
Posted by lsweeney at Nov 27, 2009, 2:29:06 PM
I am having the same problem. I am also a newbee. I am running XP with the latest MS updates with Java 6.0.170, & NVIDIA Gforce 8600 GT. I also have a problem while working on a plan view. Periodically additional graphic boxed are displayed over the top of my working image. When I save the file and close the program and restart everything works fine for a while.
Posted by Pitouille at Nov 27, 2009, 3:18:42 PM
On my side the problem solved from itself after a few reinstall desinstall ... thank you MS...
