Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Sweethome3d |
| Print at Sep 19, 2026, 10:35:41 PM | View all posts in this thread on one page |
| Posted by abajwa at Nov 10, 2009, 2:21:12 PM |
Sweethome3dBother when i load the java main class then i receive this kind of error. please help me ASAP. Nov 10, 2009 2:16:39 PM javax.media.j3d.NativePipeline getSupportedOglVendor SEVERE: java.lang.UnsatisfiedLinkError: no j3dcore-ogl-chk in java.library.path Exception in thread "main" java.lang.UnsatisfiedLinkError: no j3dcore-d3d in java.library.path at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1682) at java.lang.Runtime.loadLibrary0(Runtime.java:823) at java.lang.System.loadLibrary(System.java:1030) at javax.media.j3d.NativePipeline$1.run(NativePipeline.java:231) at java.security.AccessController.doPrivileged(Native Method) at javax.media.j3d.NativePipeline.loadLibrary(NativePipeline.java:200) at javax.media.j3d.NativePipeline.loadLibraries(NativePipeline.java:157) at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:987) at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:299) at javax.media.j3d.GraphicsConfigTemplate3D.getBestConfiguration(GraphicsConfigTemplate3D.java:321) at java.awt.GraphicsDevice.getBestConfiguration(GraphicsDevice.java:158) at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Component3DManager.java:63) at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Component3DManager.java:75) at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(SweetHome3D.java:449) at com.eteks.sweethome3d.SweetHome3D.createApplication(SweetHome3D.java:389) at com.eteks.sweethome3d.SweetHome3D.main(SweetHome3D.java:196) |
| Posted by Puybaret at Nov 10, 2009, 6:11:03 PM |
Re: Sweethome3d How did you launch Sweet Home 3D? If you build yourself Sweet Home 3D from the sources, did you read the part of the README.TXT file that mentions "java.ext.dirs"? By the way, please no "ASAP" in messages. Support is free, so don't ask too much. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by meleonid at Mar 5, 2011, 1:34:11 PM |
Re: Sweethome3d For newbies like me: please make sure that your're using JRE5. I recieve exception above on JRE6 even with VM parameters from Readme.txt specified. With JRE5 everything works OK. |
| Posted by Puybaret at Mar 5, 2011, 3:23:42 PM |
Re: Sweethome3d Leonid, sorry to contradict you, but it works with Java 6 too. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by meleonid at Mar 7, 2011, 11:16:59 AM |
Re: Sweethome3d Emmanuel, that's good! Looks like I did something wrong, because SH3D didn't passed about 10 unit tests and didn't started UI because of error above until I reconfigured it to Java 1.5 VM :( Anyway, now it works great! |
| Posted by Cardinal at Jul 4, 2011, 5:37:10 PM |
Re: Sweethome3d Hello, I have the same stacktrace reported above. I've tried adding the VM argument as described in the readme file with no success. When I do this I get a different stacktrace but the same Exception : Exception in thread "main" java.lang.UnsatisfiedLinkError: no j3dcore-d3d in java.library.path I am totally unfamiliar to Java 3D so I'm wondering if there's anything in particular I need to do (download? install?) prior to trying to run SH3D on eclipse? Thanks in advance. |
| Posted by Cardinal at Jul 4, 2011, 6:55:52 PM |
Re: Sweethome3d Well I restarted eclipse and somehow it works. Sorry for the trouble. |
Current timezone is GMT Sep 19, 2026, 10:35:41 PM |
