Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Furniture not importing on MacBook Air M1 |
| Print at Sep 20, 2026, 11:59:55 AM | |
| Posted by wismeijer at Feb 13, 2022, 12:33:16 PM |
Furniture not importing on MacBook Air M1 Hi guys, having trouble importing new furniture on SH3D. When I download a (Collada) ZIP file from 3D Warehouse, I can load it but when the orientation screen appears SH3D 'hangs' and I have to force quit the app. Anybody else having this problem? Version used: Versie 6.6.1 Mac App Store OpenJDK versie 15.0.2 - 64bit - ARM - 0,1 / 4 GB geboden door Azul Systems, Inc. Java 3D versie 1.6.1 - JOGL 2.4.0-rc-20210111 |
| Posted by Puybaret at Feb 13, 2022, 6:55:45 PM |
Re: Furniture not importing on MacBook Air M1 Try to run the program with Rosetta at least while you import a 3D model. What macOS version do you use? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by snortrip at Feb 14, 2022, 12:53:15 PM |
Re: Furniture not importing on MacBook Air M1 I had a similar problem. So far, unfortunately, I could not find a solution. ---------------------------------------- My favorite collection of 3D furniture models is here. |
| Posted by Puybaret at Feb 14, 2022, 3:41:56 PM |
Re: Furniture not importing on MacBook Air M1 snortrip, are you sure you use Sweet Home 3D 6.6.1 like wismeijer? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by UbuntuBirdy at Mar 5, 2022, 9:53:34 PM |
Re: Furniture not importing on MacBook Air M1 I have the same problem with the current version of SH3D for Linux on Ubuntu 21.10. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by pharmonie at Mar 7, 2022, 3:01:38 PM |
Re: Furniture not importing on MacBook Air M1 Same here. MacBook Pro 14" 2021 with M1 Pro. It's freezing in the orientation view after selecting in obj file to import. using Sweet Home 3D Version 6.6a. Did you guys find any workaround yet? I can confirm, that importing entire libraries is working. |
| Posted by Puybaret at Mar 7, 2022, 4:17:28 PM |
Re: Furniture not importing on MacBook Air M1 Pharmonie, your case is a little different because you use the free version in which case you should use the special version available at https://www.sweethome3d.com/downloads/SweetHome3D-6.6-macosx-jogl-2.3.2.dmg As this version can't be notarized, you'll have to launch it the first time by clicking on Sweet Home 3D icon while maintaining control key pressed and choosing Open item. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by UbuntuBirdy at Mar 7, 2022, 11:05:59 PM |
Re: Furniture not importing on MacBook Air M1 As a workaround I import the models with the FLE, save it in a library and then import that library with SH3D. Works for me with Ubuntu 21.10 and SH3D 6.6. Hope that's a (temporary) solution for the M1 too. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by snortrip at Mar 30, 2022, 3:33:49 PM |
Re: Furniture not importing on MacBook Air M1 Pharmonie, your case is a little different because you use the free version in which case you should use the special version available at https://www.sweethome3d.com/downloads/SweetHome3D-6.6-macosx-jogl-2.3.2.dmg As this version can't be notarized, you'll have to launch it the first time by clicking on Sweet Home 3D icon while maintaining control key pressed and choosing Open item. Puybaret, thank you! This solution worked fine in my case. ---------------------------------------- My favorite collection of 3D furniture models is here. |
Current timezone is GMT Sep 20, 2026, 11:59:55 AM |
