Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: A Service Hatch leaves a white stripe on the floor. Can this be avoided? |
| Print at Sep 10, 2026, 3:17:48 AM | |
| Posted by titust11 at Jan 15, 2022, 8:16:06 PM |
A Service Hatch leaves a white stripe on the floor. Can this be avoided? For a wardrobe opening, I create a service hatch in the wall, planning to add some sliding doors later. No matter what I do in the location where the hatch is, there is a white stripe on the wooded floor texture. Am I doing something wrong or can I overcome this problem by applying a trick, or using something else other than a hatch to make a wall opening? Thanks |
| Posted by hansmex at Jan 15, 2022, 10:16:05 PM |
Re: A Service Hatch leaves a white stripe on the floor. Can this be avoided? If you insert an inverted u-shaped object into a wall, the wall will fill up. If you add a closing part at the bottom, that part will leave a gap in the floors you insert afterward. The trick is to make an insert with a bottom closing part that is as thin as possible, making it almost invisible. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by UbuntuBirdy at Jan 15, 2022, 10:28:06 PM |
Re: A Service Hatch leaves a white stripe on the floor. Can this be avoided? The trick is exactly to take an inverted U. A door frame without the bottom piece. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by titust11 at Jan 15, 2022, 11:46:34 PM |
Re: A Service Hatch leaves a white stripe on the floor. Can this be avoided? But how can I modify only the bottom part (the base) of a rectangular insert? What furniture should I import in the beginning to start with? |
| Posted by UbuntuBirdy at Jan 16, 2022, 12:17:08 AM |
Re: A Service Hatch leaves a white stripe on the floor. Can this be avoided? Try a simple door and turn all the materials to "invisible" (or at least the bottom part). ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by Puybaret at Jan 16, 2022, 4:26:46 PM |
Re: A Service Hatch leaves a white stripe on the floor. Can this be avoided? If you want a service hatch without its bottom, import this box, inverting front and back faces at the second step of the wizard and checking the Door or window option at the third step. Then place it on a wall and make its front, back and bottom materials invisible. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 10, 2026, 3:17:48 AM |
