Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: inconsistent results when rotating 2 objects |
| Print at Sep 6, 2026, 6:16:17 AM | |
| Posted by sjskhalsa at Jan 9, 2022, 9:04:45 PM |
inconsistent results when rotating 2 objects I followed the tip for creating an inclined roof with windows, and used the rotate about horizontal axis after importing the wall to set the angle. When I add a beam, drawn as a box, and rotate it about the same axis by the same angle it does not match the angle of the roof! I have to add 10 degrees to the rotation to get it to match. Can someone clue me in as to what is going on and which object is oriented correctly? |
| Posted by Puybaret at Jan 10, 2022, 4:00:53 PM |
Re: inconsistent results when rotating 2 objects Did you draw the exported wall horizontally to ensure that once imported it's not rotated? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 6:16:17 AM |
