Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Wirings plugin |
| Print at Sep 14, 2026, 12:47:59 AM |
| Posted by Daniels118 at Jan 6, 2022, 3:15:12 AM |
Wirings pluginMy plugin for electrical installations is finally ready! This plugin brings to SH3D the capability to draw 3D polylines that will snap to floors, walls and ceilings, directly in the 3D view. This could be useful to draw electrical installations, plumbing, and simple decorations. In order to use this plugin you have to install Pan3dView plugin version 1.7 or later. The plugin comes with an integrated user guide available in english and italian under the Help > Draw wirings help menu, please take a moment to read it to learn how to use the plugin. Features
Here some screenshots: ![]() ![]() ![]() ![]() Download from here: Wirings plugin |
| Posted by hansmex at Jan 6, 2022, 7:31:34 AM |
Re: Wirings plugin Daniele, Thank you for version 1 of this new plug-in. Unfortunately I cannot get it to work. What did I do: - I made sure I have Pan3D v1.7 installed - I made sure I have Wiring v1.0 installed - I open a new, empty instance of SH3D - ! draw a square of 4 walls and insert a room - I click the button of the Selection pointer - I click the button of the Wiring tool. - The background of the Wiring tool turns blue. If I click the button again, the blue background turns white again. That's it. Nothing else happens. The last button clicked (before clicking the Wiring Tool), determines which action is executed AFTER clicking the Wiring button. If that's clicking the Selection button then the program stays in Selection mode after clicking the Wiring button. When I click a wall to start drawing wiring, I move the wall. When I clcik a floor, I move the floor. When (before clicking the Wiring button) I click the Walls button, then after activating the Wiring plugin, I will draw a wall, not wiring. - Variations: I tried it on an existing design, I tried it on a new level with equal elevation called WIRING, I tried it with Baseplan Locked. Nothing happens. I have several other plug-ins installed. Maybe your (combination of) plug-ins doesn't like some of the other plug-ins? I read your HELP file several times. Any suggestions?? Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Daniels118 at Jan 6, 2022, 9:00:39 AM |
Re: Wirings plugin Hello Hans, and thank you for downloading. From your description I suspect you're trying to draw wirings in the plan view (2D), but this is not supported because it would be impossible (or at least very unfriendly) to set the elevation of each point. You have to draw wirings directly on the 3D view by clicking on a wall side surface or on a floor. The button on the toolbar have to be highlighted blue, it doesn't matter which one of the default tools are enabled since they works only in the plan view. Please let me known if you still experience problems, I could eventually make a video tutorial. |
| Posted by hansmex at Jan 6, 2022, 2:21:45 PM |
Re: Wirings plugin Yes, now it works.... Thank you once again!! Has ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Daniels118 at Jan 7, 2022, 11:28:25 AM |
Re: Wirings plugin Glad to hear that! I'm currently working on these new features:
I'm considering to implement the following features too, but I'm not sure if I really need them:
I've prepared a quick poll, if somebody want to take a minute to reply and I'll receive enough feedback I could add the above features to the roadmap: express your wishes |
| Posted by hansmex at Jan 7, 2022, 1:12:56 PM |
Re: Wirings plugin I haven't had time to test your plug-in extensively. Nevertheless, if I may make a suggestion: - Insert wiring into the active level, so that you can create individual levels (visible or not) for water, electricity, etc. - Divise a way to (more) precisely draw wiring, e.g. start 100 cm from corner and place 100 cms above floor Keep up the good work :-) Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by YGYL at Jan 7, 2022, 3:19:24 PM |
Re: Wirings plugin Really 2 great plug-ins, at once to achieve many people's expectations for many years!!!!! |
| Posted by Daniels118 at Jan 10, 2022, 2:14:19 AM |
Re: Wirings plugin A new version is available! @Hans - wirings are added to the active level since first release :) - I have introduced 2 new features to increase drawing precision: measurement labels and snap to 90° angles! List of changes in 1.1
![]() (2) Measurement labels: ![]() Download Wirings 1.1 |
| Posted by YGYL at Jan 17, 2022, 4:01:48 PM |
Re: Wirings plugin I tested it and it works very well, thanks a lot But I seem to have encountered a bug when I was testing Show/Hide, and it doesn't show up after hiding. But it didn't reproduce it later At that time there were lines of the same color but with different bends |
| Posted by Daniels118 at Jan 18, 2022, 1:56:45 AM |
Re: Wirings plugin @YGYL Thank you for your feedback! I never faced this problem, however if you'll find out how to reproduce the bug please report the detailed steps so that I can reproduce and fix it. A little spoiler on my work in progres: ![]() |
Current timezone is GMT Sep 14, 2026, 12:47:59 AM |
