Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Worked on previous installations of Linux, now won't load |
| Print at Sep 29, 2026, 7:49:44 PM | View all posts in this thread on one page |
| Posted by GregTheHun at Nov 30, 2021, 10:06:04 PM |
Worked on previous installations of Linux, now won't load So, it appears even using the same hardware as before. I get stuck on the splash image and now it won't even load. Here are my specs (I know what you're going to say, but it had worked before): CPU: 6-Core AMD Phenom II X6 1100T (-MCP-) speed/min/max: 803/800/3300 MHzHere is the output when run from the command line: OpenJDK 64-Bit Server VM warning: Ignoring option --illegal-access=permit; support was removed in 17.0Any further information I can grab if you need me to run a command. Thanks in advance. |
| Posted by Puybaret at Dec 1, 2021, 12:25:48 PM |
Re: Worked on previous installations of Linux, now won't load Sweet Home 3D can't run with Java 17 at the moment. Use an other Java version or the installer version available at Download page. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by GregTheHun at Dec 1, 2021, 5:20:37 PM |
Re: Worked on previous installations of Linux, now won't load So, it looks like I have a few installed, is there a way I can specify which one to use? extra/icedtea-web 1.8.8-1 [installed] |
| Posted by GregTheHun at Dec 1, 2021, 5:34:27 PM |
Re: Worked on previous installations of Linux, now won't load Nvm, uninstalled newer java version, and for Linux (Manjaro) specifically had to specify JAVA_HOME environment variable. (I use fish shell, probably works in bash) |
| Posted by GregTheHun at Oct 13, 2022, 7:28:47 PM |
Re: Worked on previous installations of Linux, now won't load So, slightly different issue, I'm kind of a system hopper. So, now mine looks like this: CPU: 12-core AMD Ryzen 9 5900X (-MT MCP-) speed/min/max: 3676/2200/4950 MHzHowever, this time, I have openjdk-11: /usr/lib/jvmWhen I try to just run it in the terminal, works fine. However, trying to run it from the Gnome menu (gnome 42, in arch). It appears to give me nothing. What gives? |
Current timezone is GMT Sep 29, 2026, 7:49:44 PM |
