Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Photo creation problem |
| Print at Aug 21, 2026, 9:01:36 PM |
| Posted by frevandonanet at Oct 31, 2009, 2:37:16 PM |
Photo creation problem Hi, I've just downloaded SweetHome and started to play around with it. Everything worked fine until I tried to create photos. I'm able to create the photos with quality 0 or 1, but when I try photos with quality 2 or 3 I get a black figure. I'm using ubuntu 9.04. I tried to run SweetHome in 3 different ways (with java webstart, with the download installer and with the jar file) and always got the same results. Any help will be welcomed. Thanks. Alexandre |
| Posted by frevandonanet at Oct 31, 2009, 2:49:55 PM |
Re: Photo creation problem By the way, the problem only appears when I use virtual view. With the aerial view, it works fine. |
| Posted by califdon at Oct 31, 2009, 7:53:01 PM |
Re: Photo creation problem I'm having a similar, but more severe problem with Sweet Home 3D on WIndows XP. I cannot create a photo at all. For about 1 second, there is an activity status indicator, then a small red X in the center of the frame. I do not have a video card, just the onboard video controller. I am very pleased with the software, but it would really be nice to be able to create photos. |
| Posted by califdon at Nov 1, 2009, 1:34:04 AM |
Re: Photo creation problem Update: I can indeed create a 3D photo, but only at "best" quality setting (which is OK). Anything less than that, it will not work. Seems like the same problem in Ubuntu described in the original post. |
| Posted by carolaclavo at Nov 6, 2009, 3:57:03 PM |
Re: Photo creation problem Hello, I'm also newbie, just downloaded the application a few days ago and it's great to plan my next move to a new flat ;) It is a GREAT application!! But when I want to save a photo, I can't use highest quality, it just starts and stops after rendering a few % In my case I'm using a Mac and the latest version. Thanks for any help :) |
| Posted by carolaclavo at Nov 6, 2009, 3:59:36 PM |
Re: Photo creation problem This is what I get. It starts working but after rendering 11 little squares or portions, it gets stuck. [URL=http://img689.imageshack.us/i/capturadepantalla200911b.png/][IMG]http://img689.imageshack.us/img689/1346/capturadepantalla200911b.th.png[/IMG][/URL] |
| Posted by Puybaret at Nov 7, 2009, 6:27:50 PM |
Re: Photo creation problem Your image ![]() makes me think about this bug. Miserably, it's not fixed yet. Could you try to remove the objects under the green or red squares, and check if rendering still fails? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by carolaclavo at Nov 7, 2009, 10:46:21 PM |
Re: Photo creation problem Hi there! I made a new project with no furnitures at all, just windows (only one in the photo to be created) and the rendering still failed. It fails in two fashions; one of them while working, with red or green squares displayed as before, or in the other style, showing a red 'x' like the image was missing. Thanks! |
| Posted by Puybaret at Nov 9, 2009, 8:43:08 PM |
Re: Photo creation problem Please try this: 1. Launch Console program found in /Applications/Utilities folder and click on Clear display. 2. Launch Sweet Home 3D and try to create a photo. 3. Console program should display some new text that will help me a lot to guess your issue. Please select that text and copy paste it in a comment here. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by MarcSc at Nov 9, 2009, 10:23:06 PM |
Re: Photo creation problem Just a silly question, does the partition have enough free space? Perhaps tmp is full, or the path Sweet Home 3D is using for output is full? |
Current timezone is GMT Aug 21, 2026, 9:01:36 PM |
