Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: walls of length x that will produce room of length y? |
| Print at Aug 19, 2026, 6:45:01 AM | View all posts in this thread on one page |
| Posted by Bearpecs at Oct 25, 2021, 7:08:15 AM |
walls of length x that will produce room of length y? I want to do what the user guide instructed and make walls before clicking to create rooms. But if I make 4 walls of 20' each, the resulting room is not 20x20 but smaller. (How much smaller depends on the thickness of the wall.) Is there a formula I can use to create walls that will give a room that's 20x20? thanks |
| Posted by hansmex at Oct 25, 2021, 4:43:36 PM |
Re: walls of length x that will produce room of length y? (start wall thickness ./. 2) + wall length + (end wall thickness ./. 2) ./. = divided by H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by UbuntuBirdy at Oct 25, 2021, 10:35:34 PM |
Re: walls of length x that will produce room of length y? Or the short way (Hans explained it absolutely correct) desired wall length plus wall thickness. For a 20x20 room your walls need to be 20 + (wall thickness) long. Why? Because the mesurepoint is always at the center of the wall (thickness). Choosing an even value for the wall thickness makes the math easier... ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by dorin at Nov 8, 2021, 9:59:10 AM |
Re: walls of length x that will produce room of length y? Maybe this mini tip could be useful. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Aug 19, 2026, 6:45:01 AM |
