Print at Aug 12, 2026, 9:38:37 PM
Posted by TM007 at Sep 22, 2021, 9:58:26 AM
An arch roof
Hello.
Newbie asks that how I do an arch roof to a room? Like cave ceiling? We have some 3m width room and according to test (as a normal wall) arch extent is 118 degrees. In other words the arc is bent some 80 cm. Rgs, TM007
Posted by hansmex at Sep 22, 2021, 5:02:21 PM
Re: An arch roof
- Draw a wall of the length needed (3 mtr)
- Use Modify walls - Arc extent and set it to 118 degrees
- Apply texture(s) on inside and/or outside (rotate 90 degrees if needed)
- Export selection
- Import and rotate 90 degrees
Posted by TM007 at Sep 22, 2021, 6:12:48 PM
Re: An arch roof
Hello hansmex. Thanks about guiding. I followed maybe wrong Your instructions because I couldn't "flip" the arch to top of the room. I try harder. Anyway nice to know that it is easy to make own library elements! Nice feature.
Posted by TM007 at Sep 22, 2021, 6:25:09 PM
Re: An arch roof
This is missing in Mod walls : "(rotate 90 degrees if needed)
Posted by hansmex at Sep 22, 2021, 7:17:49 PM
Re: An arch roof
Read the user guide on how to export part of a model, and in how to import and rotate it.
