Print at Sep 6, 2026, 5:32:13 AM
Posted by mav99l at Aug 26, 2021, 1:58:47 AM
Convert to Autocad or DWG or DXF
Hi all,
I'm trying to send my drawing to a structural engineer but he needs to import it to autocad to view it. How do I do convert the file for him to import?
Thanks in advance :-)
Posted by hansmex at Aug 26, 2021, 9:50:55 PM
Re: Convert to Autocad or DWG or DXF
Did you try Google ?
Posted by mav99l at Aug 27, 2021, 2:57:44 AM
Yes, and I searched this forum as well but no luck.
Posted by hansmex at Aug 27, 2021, 6:09:40 AM
Did you follow the link I sent you, and read the article on Rea-converter?
Posted by mav99l at Aug 27, 2021, 8:46:38 AM
Hi. I did. When I output to OBJ, I get many files including on OBJ and many PNG and jpg. I select the OBJ in Rea-converter and it converts. Then I open it with Autodesk DWG Truview, but it's a bunch of vector lines and not usable. What am I doing wrong?
Posted by hansmex at Aug 27, 2021, 11:22:57 AM
This is the wrong forum to ask questions on Rea. Maybe search for a different method, or try a DXF converter.
SH3D was never meant to produce files for those programs.
Posted by mav99l at Aug 27, 2021, 12:09:28 PM
I've tried still can't get it to create a file that retains the 3d structure and measurements and can be used in an autocad setting.
Posted by hansmex at Aug 27, 2021, 12:51:20 PM
Autocad is a program with a proprietary file sytem, kind of a black box.
Talk to your engineer and ask him/her to install SH3D.
Posted by KitchM at Jan 15, 2023, 9:32:35 PM
angry   Re: Convert to Autocad or DWG or DXF
This is a hugely serious problem for the program. So much better to have the necessary file conversions built in. Should have been some sort of open format. We waste a huge amount of time learning a new program and then creating a drawing no one can use. I'd be happy with a simple 2D file export in a usable format.
These appear to be the ones that Autocad can handle: https://knowledge.autodesk.com/support/autoca...s-can-AutoCAD-import.html
I'm going to try to print to PDF and see if that works.
(Of course, a person who is conversant in Autocad will not want to install SH3D.)
Posted by Puybaret at Jan 15, 2023, 10:22:44 PM
SH3D format is opened, not DWG or DXF formats which are proprietary file formats. Ask to Autodesk to support SH3D format, like some other editors did (like Live Home 3D).
Meanwhile, don’t use Sweet Home 3D if it doesn’t fit your needs!
Posted by Keet at Jan 16, 2023, 9:00:53 AM
I've read here in the form multiple times where SH3D is used next to Autocad to visualize designs for clients so this is an unfounded remark.
Concerning your format conversion problem: try to use freeCad to import an obj export from SH3D and save it as DXF. I have no idea how well that works but it's worth a try. You might have to do this in parts.
You can also try one of the many online converters but in my experience they don't work too well with full plan exports.
Posted by dorin at Jan 16, 2023, 2:50:47 PM
Maybe you have to read this
For me it work between me and other coworkers with AutoCAD or ArchiCAD.
They don't need to install nothing. I send them only the dxf file.
Posted by Rolinger at May 16, 2023, 11:41:45 AM
I'll revive the thread since I have a specific workflow that produces extremely good results:
In order to obtain an accurate cross-section or even a floor plan, the following steps must be taken:
1. Export the complete model in *.obj format
2. Import the model into Blender
3. Export the model in DAE format from Blender
4. Load the DAE model into Sketchup
5. Scale the model to obtain the appropriate scale of the model
6. Use Tools->Section plane and set the section plane to the appropriate position
7. Select "section plane" with the right button and select "Create group from section plane"
8. The group of elements created in this way can be moved to appropriate places outside the model and in this way more groups or cross sections can be made
9. Select the groups formed in this way and use the plugin "Export to dxf or dwg"
I use SketchUp Make 2016 for this purpose and things work perfectly.
However, I secretly hope that Puybaret will make a plugin that will enable this procedure directly in SH3D ;-)
Best regards
Posted by Dweinn at Jul 25, 2023, 2:49:50 PM
Intriguing exchange on design file conversions here! If anyone's seeking a less circuitous route, the Vector Converter on Converter365 could be your saviour. It swiftly turns your SH3D exports into DXF without any software juggling - maintaining quality while saving you time. Try turning your design dreams into DXF realities in just a few clicks with this "vector converter ". Less hassle, more design power at your fingertips!
Posted by Xlance at Apr 20, 2025, 3:34:46 AM
from sweethome3d to autocad
saveas .svg > open in inkscape > saveas.dxf or .dxf v12
https://mydxf.blogspot.com/2008/11/inkscape-r12-dxf.html?m=1
_________
from autocad to sweethome3d
load cad2walls.lsp inside autocad > export as cad2walls.input.txt >
use cad2walls.jar > saveas cad2walls.output.sh3d
https://sourceforge.net/p/sweethome3d/plug-ins/56/
Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins
Posted by StefanM83 at Jun 28, 2025, 8:09:04 PM
Hi there,
This is an old topic, but it's still relevant.
How do you scale the SVG according to the measurements defined in SH3D?
Thanks!
Stefan
Posted by KitchM at Jun 30, 2025, 5:19:39 PM
I just have to take a moment and agree that, while this may be considered old, it is still a very good thread for reference to the conversion problem. I am glad others are finding good means to accomplish the conversion, and new methods are certainly welcome.
The scaling issue is a fine question. I am wondering if this is a function of the target program. There are two sides to scaling. One is often viewed as a zoom issue, and the other has to do with a change in the relationship between the axes.
I cannot imagine that the axes relationship should ever change in any conversion process, else the process would be considered flawed. Am I wrong about that?
Posted by SpaceMushrooms at Jul 9, 2025, 1:22:55 PM
Want to create your own custom 3D object?
Now you can!
We’re giving our most passionate design enthusiasts the unique opportunity to meet directly with our talented 3D modelist and design a one-of-a-kind object of their choice — give freedom to your imagination!
How to participate?
Simply join the challenge (details below), share your project, and you could win this exclusive experience.
Don’t miss this chance to add something truly special to your Sweet Home 3D library.
Enter now and turn your imagination into reality!
Challenge:
Theme: Your dream home — unleash your creativity and show us how you imagine your perfect house. The Dream House should leave plenty of room for dreams, so think big and without limits! Let your imagination run wild!
How to participate:
- Follow our Instagram page @sweethome.3d
-Send us your project via Instagram DM
- Stay tuned for daily updates and prepare to compete with other amazing designs!
Every day, we will share updates exclusively on our Instagram channel @sweethome.3d, and our followers will vote in daily polls to decide who moves forward to the final. It will be the community that chooses the winner!
