Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Raise the ground floor |
| Print at Oct 15, 2026, 9:03:43 AM | |
| Posted by ddt57 at Aug 8, 2021, 5:09:22 AM |
Raise the ground floor How to raise the ground floor to 10 cm..? like skecthup with pushpul/down tks |
| Posted by hansmex at Aug 8, 2021, 1:22:12 PM |
Re: Raise the ground floor Onder a level at 10 cm elevation and build your house/room there. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by ddt57 at Aug 8, 2021, 2:45:26 PM |
Re: Raise the ground floor but this is on the ground floor, not on the second level, because there is no elevation |
| Posted by hansmex at Aug 8, 2021, 7:56:05 PM |
Re: Raise the ground floor It isn't exactly clear what you want. You could add a level at -10 cm and the house would be below the ground... H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by ddt57 at Aug 9, 2021, 9:17:12 AM |
Re: Raise the ground floor sorry, I mean how to thicken the floor to 10 cm at level 0 |
| Posted by hansmex at Aug 9, 2021, 9:22:11 AM |
Re: Raise the ground floor Assuming you don't have any levels yet: 1 - add a second level, this creates two tabs for the levels 2 - select and double click the tab for the lower level 3 - change the floor thickness. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by ddt57 at Aug 10, 2021, 6:59:27 AM |
Re: Raise the ground floor thanks for explanation, very helpful |
| Posted by ddt57 at Aug 10, 2021, 7:53:51 AM |
Re: Raise the ground floor how to make a hole in the wall..? |
| Posted by VeroniQ at Aug 10, 2021, 11:47:36 AM |
Re: Raise the ground floor Hi ddt57, Did you notice the different tips in the blog? Many of them might also help you. |
Current timezone is GMT Oct 15, 2026, 9:03:43 AM |
