Print at Oct 15, 2026, 8:14:25 AM View all posts in this thread on one page
Posted by ddt57 at Aug 8, 2021, 5:09:22 AM
Raise the ground floor
How to raise the ground floor to 10 cm..? like skecthup with pushpul/down
tks
Posted by hansmex at Aug 8, 2021, 1:22:12 PM
Re: Raise the ground floor
Onder a level at 10 cm elevation and build your house/room there.
Posted by ddt57 at Aug 8, 2021, 2:45:26 PM
but this is on the ground floor, not on the second level, because there is no elevation
Posted by hansmex at Aug 8, 2021, 7:56:05 PM
It isn't exactly clear what you want. You could add a level at -10 cm and the house would be below the ground...
Posted by ddt57 at Aug 9, 2021, 9:17:12 AM
sorry, I mean how to thicken the floor to 10 cm at level 0
Posted by hansmex at Aug 9, 2021, 9:22:11 AM
Assuming you don't have any levels yet:
1 - add a second level, this creates two tabs for the levels
2 - select and double click the tab for the lower level
3 - change the floor thickness.
Posted by ddt57 at Aug 10, 2021, 6:59:27 AM
thanks for explanation, very helpful
Posted by ddt57 at Aug 10, 2021, 7:53:51 AM
how to make a hole in the wall..?
Posted by VeroniQ at Aug 10, 2021, 11:47:36 AM
Hi ddt57,
Did you notice the different tips in the blog? Many of them might also help you.
