Print at Aug 21, 2026, 10:28:00 AM
Posted by maxfri at Oct 19, 2009, 1:12:56 PM
Problem with "Create photo function"/Internal Renderer
Hi there,
I have a problem with the internal renderer.
When i create or import a big project and start to render the renderer stops at a certain point.Im not able to finish a photo.This happens at all render settings except the fast setting.
I testet the sunflow renderer standalone where i can adjust the virtual memory.
Is there any option to change the memory for the internal renderer ???
Or is there a commandline to change the virtual memory ?
I tested the -Xmx and -Xms settings but there is no change.
The pictures looks quiet nice but the half of the pic is always black.
Hope you can help me,
Greetings
Posted by Puybaret at Oct 19, 2009, 8:38:49 PM
Re: Problem with "Create photo function"/Internal Renderer
Download the latest Jar executable file SweetHome3D-x.y.jar at http://sourceforge.net/projects/sweethome3d/files/
and run the following command if you want to allocate 1024 MB at max:
java -Xmx1024m -jar path/to/SweetHome3D-x.y.jar
Posted by csfrost at Oct 27, 2009, 4:29:21 AM
I'm having the same problem. 'Create Photo' worked fine a half dozen times and now will no longer execute - hangs the app.
I've downloaded the .jar file, and it's in my SH3D holder. I presume the instruction above it to launch a CMD line and use the "java" command. The 'DOS' line command responds with "java is not recognized as an internal or external command".
Cool program. Rendering the photos is a cool feature. I'd like to use it again. What am I still doing wrong?
Thanks for your help.
csfrost
Posted by Puybaret at Oct 27, 2009, 11:20:52 AM
Instead of entering directly "java", you have to write the full path of "java".
It will probably be:
C:\Program Files\Java\jre6\bin\java.exe
Then the command will become:
"C:\Program Files\Java\jre6\bin\java.exe" -Xmx1024m -jar path/to/SweetHome3D-x.y.jar
There's an other solution, create a text file named SweetHome3D.l4j.ini in the same directory as SweetHome3D.exe, and write the following text in that file:
-Xmx1024m
and relaunch Sweet Home 3D.
Posted by csfrost at Oct 29, 2009, 6:35:21 AM
Emmanuel -
Thanks for both your Dev skils and your support.
I am still unsuccessful with either solution.
Solution #1: Excuse my ignorance, but my Vista 64 system has not 'Java' directory, so I'm unable to point to it, per your syntax.
Solution #2: I have executed (I believe) precisely per your direction - a file called SweetHome3D.l4j.ini in the App directory, with the single command pasted into it. No results.
Which is odd, because the modeling rendered almost a dozen times successfully before it stopped. Sometimes now the little green and red 'scanners' that paint the photo simply paint black space until it freezes. I've relaunched, rebooted... still no fix.
I'm open to suggestion. Thanks again for your support.
-=sf=-
Posted by carolaclavo at Nov 6, 2009, 4:05:00 PM
-Xmx1024m
Is there anything like this I can do on the Mac version? I'm not able to save a photo in high quality. Thank you :)
Posted by Puybaret at Nov 7, 2009, 6:40:04 PM
If you open the Info.plist file in the Sweet Home 3D.app folder, you'll see that it contains the following text:
<key>VMOptions</key>
<string>-Xmx1024m</string>
meaning the Mac OS X version of Sweet Home 3D installer (and the Linux version too) already requires 1024 MB at max.
In version 2.1, I decreased max memory to 512 MB only for Windows installer and Java Web Start version, because the could not create the Java virtual machine bug was reported only for Windows.
Posted by carolaclavo at Nov 7, 2009, 10:40:30 PM
Thank you for your reply :)
Posted by slobadog at Oct 31, 2010, 4:23:45 AM
I am experiencing a similar problem. All was working well until I added some drawers in the kitchen. Now the best and second best photo's render an all black screen. The quick and next up work fine. I have added the file SweetHome3D.l4j.ini.
I'm using Win7 with SH3D V2.6 with Java V1.6.0_21 and my home file is 22.5Mb.
Thanks for any help, much appreciated.
Posted by slobadog at Oct 31, 2010, 6:16:06 AM
I guess it was just too much info for the renderer. I moved the point of view forward 2 meters and it now works...
Posted by hansmex at Oct 31, 2010, 7:52:56 AM
Slo,
If your problem was solved by moving the virtual visitor 2 mtr, than most probably the v.v. was in a wall ......
Posted by Puybaret at Oct 31, 2010, 1:12:15 PM
I should a warning or something like that when the virtual visitor is on a wall. What's your opinion?
Posted by hansmex at Oct 31, 2010, 1:31:55 PM
Emmanuel,
Maybe you could do something else... When magnetism is "on", windows attach themselves "inside" walls, and objects attach themselves "against" walls. Maybe it's possible to do something similar with the virtual visitor? It's either on one side of the wall, or on the other side of it. Only when you move it with the cursor keys, can you position it inside the walls.
