Print at Sep 6, 2026, 8:19:11 AM
Posted by zuize411 at Jun 8, 2021, 1:16:12 PM
Adding a crawl space afterwards
Hi! Thanks for this great program!
I am trying to add a crawl space after I have designed the other levels (my mistake). So I added a new level with some walls, set elevation to 0 and added the height of the crawl space as elevation value to the other levels (3 levels). All elements, furniture etc. are now correctly elevated but the walls are not elevated. The walls of the ground floor are e.g. still on the ground (and therefore obscuring the crawl space). They should be on top of the crawl space. I have done houses with basements before (negative elevation) but then I have always started with the lowest level. Now I am trying to add it afterwards. What am I doing wrong?
Posted by hansmex at Jun 9, 2021, 8:00:44 AM
Re: Adding a crawl space afterwards
Several possibilities, hard to say without seeing your design.
Can you share it?
Posted by digitaltrails at Jun 10, 2021, 2:33:01 AM
Perhaps you could try and create a new model with the right levels and then cut and paste all the content of the old model into the correct levels of the new model.
