Print at Sep 20, 2026, 2:10:02 PM
Posted by bbxrider at Jun 7, 2021, 3:21:52 AM
2d furniture render problem
after adding a library and a model, the 2d view doesn't show the furniture detail. existing furniture lost theirs and when trying to add again it is also blank
added Contributions.sh3f and kitchenSmallLowerCabinet.mtl
Posted by hansmex at Jun 7, 2021, 9:06:34 AM
Re: 2d furniture render problem
Check File -> Preferences -> Furniture icons in plan
Here you can choose Top view to see your furniture.
Hopefully that solves your problem
Posted by bbxrider at Jun 8, 2021, 7:44:04 PM
thanks, I reinstalled and it fixed the render so I don't know if the 2d box was unchecked, it appears the default install has it checked and I never changed it so not sure what happened. then suddenly all the furniture had the toilet pic, so I reinstalled again and it fixed that. my win10 os is running on a 128gb ssd, which is the c drive. so to save space there I installed sweet home on a hdd. perhaps that is making it flakey? I have other programs installed on the hdd and they seem to run ok. I have been using sweet home for 2 years before on a standard hdd which was the default c drive and never had any problems like this
