Print at Sep 23, 2026, 10:20:15 PM View all posts in this thread on one page
Posted by MT1976 at Jun 3, 2021, 7:16:52 PM
3d preview super slow
Hi all, I have used SH3d until a couple of weeks ago and everithing was perfect. After some windows 10 update, suddenly 3d preview became terribly slow, it freeze every time i try to use it. I ve tried to uninstall and re-instal with "free version available at SourceForge.net " and "Launch Sweet Home 3D with Java Web Start". nothing both version does not work anymore. any ideas how to solve it?
Posted by Puybaret at Jun 5, 2021, 11:18:12 AM
Re: 3d preview super slow
Maybe you imported a 3D model that slows down the program.
Could you check how the demos available in the Gallery or in File > New from demo menu item behave?
Posted by HIdayatsyah at Aug 4, 2021, 11:40:11 PM
I manage to make my rendering process a bit faster by adding the "Javaw.exe" as a "game" into my AMD Radeon Setting.
I copy this steps from how the kids make their ROBLOX Game run faster/smoother.
Steps are:
1. Open the AMD Radeon Software setting
2. Add Game
3. Browse for location of Javaw.exe (mine is C:\Program Files\Sweet Home 3D\runtime\bin\Javaw.exe)
4. Add JavaW.exe as a game.
After adding it, I set for AMD to override the application setting on several aspects such as anti-aliasing and enable Surface Format Optimization. You may try some other combination.
I also tried to to modified windows graphics setting and add Javaw.exe /SweetHome3D.exe set as "high performance", but seems no effect by that setting.
I think this scheme might be works as well for other video cards. But, please be careful and monitor the temperature of the PC/Processor at trial. I work in a room with 25-30 C, and manage the graphic processor temperature around 60-70 C while running rendering process, and the usage of graphic processor usage is a bit higher (from 4% to 9%)
Appreciate advise from experts here whether this step is safe for my notebook. So far, SH3D application is running well in my notebook.
~Day
Mobile AMD Ryuzen7-Radeon Graphic
16MB RAM, and cups of coffee
Posted by edusson at Jun 23, 2022, 2:26:05 AM
Realize it's an old thread but I thought it may help someone.
Got similar issue, lagging on the 3D view (and even when drawing in the 2D). If I removed the floor texture it did speed up. But the unexpected thing that seems to affect it is if I display the 3D view in separate window and put that window on my second monitor. That creates a lag of 1s...
Cheers
Posted by hanabi at Jul 14, 2022, 10:47:04 AM
Steps are:
2. Add Game
Thank you so much for this; you are a lifesaver! This worked perfectly for my laptop's NVidia graphics card, and I now have a super-fast 3D view that updates in less than a second and can be smoothly panned with the mouse (updates normally took around 15 seconds previously).
Posted by Kyle2k at Aug 4, 2022, 4:50:23 PM
Steps are:
2. Add Game
Posted by Kyle2k at Aug 5, 2022, 2:42:43 AM
I posted my last message in error, my reply was inconclusive.
I quoted the colleague above asking if someone could help me with a tutorial on how to optimize the SH3D to get the most out of my RTX 2070 Super video card, don't know how to do it.
No criticisms for this wonderful software, but it's very frustrating to have a high end PC and browse with a very low FPS rate in 3d view.
Hugs and thanks!
Posted by hanabi at Nov 6, 2022, 4:31:41 AM
Kyle2k,
For an NVidia card and assuming your OS is set up the same as mine:
  • Right-click on the desktop and choose "NVidia control panel"
  • Under "3D Settings" on the left, select "Manage 3D settings", then select "Program settings" among the tabs on the right
  • Next press "Add" and then wait for a while until the "Select a program" window appears
  • Click "Browse" and then select the location of the "javaw.exe" file (mine is in the "runtime\bin" folder of the Sweet Home 3D installation location); you may need to search for that file though.
  • Click "Open" to close that window.
  • Under "2." of "Program settings", choose "High-performance NVIDIA processor"
    You should now have much faster 3D refresh rate.
Posted by Solar_Honie at Feb 10, 2024, 12:39:11 PM
Kyle2k,
Hi there! I use NVidia Geforce GTX 1660, and the red line is no where to be found on my NVidia Control Panel. Could you please help me?
