Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: There is a problem with the program. |
| Print at Aug 7, 2026, 2:25:50 AM | |
| Posted by AHuk at May 24, 2021, 7:51:49 PM |
There is a problem with the program.There is a problem with the program. After starting, it works normally for 2-3 minutes. After that, everything starts to double and glitches. What is the problem? Windows 10 Pro 20H2 Intel(R) Core(TM) i5-10600K CPU @ 4.10GHz DDR 4 - 16,0Gb NVIDIA GeForce GTX 1060 6GB |
| Posted by Puybaret at May 24, 2021, 10:28:09 PM |
Re: There is a problem with the program. Depending on your system, turn off Nahimic service or MSI afterburner / Riva Turner / Discord / NVidia Experience monitoring display software. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by AHuk at May 27, 2021, 11:34:23 PM |
Re: There is a problem with the program. Deleted NVidia Experience - didn't help. The problem persisted. ( |
| Posted by myhomemyrules at May 29, 2021, 10:25:44 PM |
Re: There is a problem with the program. I have the same problem, my graphics's a MSI. If I keep using the program, it eventually crashes into a "Sweet Home 3D will exit now because of a fatal error in the 3D rendering system of your computer." I've tried all solutions in the FAQ page. I have no problem with other java programs. |
| Posted by AHuk at May 29, 2021, 10:42:21 PM |
Re: There is a problem with the program. Disconnected another service - "Nahimic service" it all worked. Thank you! |
Current timezone is GMT Aug 7, 2026, 2:25:50 AM |
