Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: New addition to my home can I submit to an engineer |
| Print at Aug 24, 2026, 11:09:07 PM |
| Posted by mimc911 at May 2, 2021, 12:49:55 AM |
New addition to my home can I submit to an engineer I used sweet home 3D to do the draft drawing of an extension that will be added to my current house I completed six different drawings one of them include the main floor plan, east side view, west side view, piling Map, Cross section view, location of the addition on the current lot survey All these drawings are done with the exact dimensions and the dimensions are included in the drawings Can I submit it is drawings to an engineer to review and certify? If there is any way to Print the finalize the draft drawing using sweet home 3-D before I submit them to the engineer? Is there is any way I can post my drawings to get your feedback Thank you for your help Are you greatly appreciated Thank you |
| Posted by hansmex at May 2, 2021, 12:53:39 PM |
Re: New addition to my home can I submit to an engineer 1 - Printing Of course you can print. Use File -> Page Setup then File Print or Print to PDF (in case you need larger than A4/Letter size paper). 2 - Submit to engineer Of course you can. NOTE: I assume you have to comply with local regulations. This is not the forum for instructions of that kind... 3 - Check out this post on how to share your design. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by mimc911 at May 2, 2021, 9:33:11 PM |
Re: New addition to my home can I submit to an engineer Thanks for your reply I am familiar with the codes I just want to make sure that the draft drawing has the basic features and the measurements that are usually required for the engineer to make decision as to certify or not Can I attach a file for you to have a look at? Thanks |
| Posted by hansmex at May 2, 2021, 9:42:31 PM |
Re: New addition to my home can I submit to an engineer Feel free to share your file for someone knowledgeable to shed some light on your design. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by mimc911 at May 3, 2021, 5:14:49 AM |
Re: New addition to my home can I submit to an engineer I will share as soon as I am done with it Thanks for your reply appreciated |
| Posted by mimc911 at May 3, 2021, 9:57:12 PM |
Re: New addition to my home can I submit to an engineer here is the mail floor plan file https://www.mediafire.com/file/8bfnykefsaazz1...an_updated_May_3.pdf/file I will do the east side view, west side view, cross section, piling map after I get feedback on this file I added all the measurements myself, is there any option to have the measurements autopopulate when you decide to print? Thanks again |
| Posted by mimc911 at May 3, 2021, 10:19:41 PM |
Re: New addition to my home can I submit to an engineer https://www.mediafire.com/file/rowvc7hnv2lrwv...May_3%25282%2529.pdf/file https://www.mediafire.com/folder/glxc37aqugb1...34,783p3vrhc9i4a99/shared |
| Posted by hansmex at May 4, 2021, 1:47:59 AM |
Re: New addition to my home can I submit to an engineer Use the AutoDimensioning plugin? H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by mimc911 at May 4, 2021, 2:07:19 AM |
Re: New addition to my home can I submit to an engineer Thanks I just downloaded the plugin and installed it |
| Posted by mimc911 at May 4, 2021, 2:38:58 PM |
Re: New addition to my home can I submit to an engineer Did anyone got a chance to look at my file? |
Current timezone is GMT Aug 24, 2026, 11:09:07 PM |
