Print at Sep 20, 2026, 11:47:09 AM
Posted by crackwood01 at Apr 21, 2021, 2:32:18 PM
Insert a sink in a cabinet
Hi Forum!
I've been searching for a way to insert a sink into a cabinet, and still can't figure it out, i know that with SH3D you have to be creative to achieve some things. Anybody as an idea?
Let's say i need to insert a sink into this cabinet:
Posted by hansmex at Apr 21, 2021, 5:19:31 PM
Re: Insert a sink in a cabinet
- make the top invisible
- place the sink
- design a new top with a hole in it & place it
- design the new top by drawing a room with a hole, then export-import it as furniture
Posted by crackwood01 at Apr 21, 2021, 5:31:06 PM
Ok thanks for this H.
Now let's say i can't make the material invisible because it's the same material .. any ideas?
Posted by snmavronis at Apr 22, 2021, 2:15:07 AM
Just make your countertop using a floor the specified thickness like this and place as desired.
Posted by KevinKillion at May 6, 2021, 7:01:25 PM
I'd welcome your advice!
"make the top invisible"
- how do you do that? I don't see any options to change *part* of a furniture item.
"design the new top by drawing a room with a hole"
- how do you put a hole into the room?
"export-import it as furniture"
- Yay, I figured out this one, but for benefit of others this seems to do the job: Make a room and (still in the 2D view) select it, 3D View>Export to OBJ, Furniture>Import Furniture.
However :( my new object created that way has no thickness. I can change the elevation off the floor, but changing the "height" seems to have no effect, it still has no thickness. Suggestions?
Thank you!
Posted by crackwood01 at May 8, 2021, 3:01:40 AM
thanks
