Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: I got some Problems to set a Wall (Angles seems to be the problem?) |
| Print at Sep 24, 2026, 8:55:10 AM | |
| Posted by lozdigloz at Mar 31, 2021, 1:26:18 PM |
I got some Problems to set a Wall (Angles seems to be the problem?) Hello, I found your program and wanted to use it to draw my old building, as I have just submitted a building application for a change of use. The building is a bit older and then apparently people built differently than they do today. The angles that your program specifies for walls don't fit me. I have now tried to enter the whole thing as it emerges from the old architect's plan, but then I cannot set the final wall. I have attached 2 screenshots to you and hope that you will understand me despite my poor English. Does anyone know a solution? Many thanks and best regards from Germany, Tobias [img]https://i.ibb.co/y8xFDg4/try1.png[/img] [img]https://i.ibb.co/dpBWkmW/try2.png[/img] |
| Posted by hansmex at Mar 31, 2021, 11:19:01 PM |
Re: I got some Problems to set a Wall (Angles seems to be the problem?) Hold the ALT-key and make your last point, or disable Magnetism in Preferences. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by lozdigloz at Apr 1, 2021, 2:58:13 PM |
Re: I got some Problems to set a Wall (Angles seems to be the problem?) Yeah, thank you - deactivating magnetism was the key ;) for my problem!But now i have another question, maybe you can help me also out with this... is it possible to display the door and window widths and heights in the plan? those from the building authority would like to have it in a special way... :/ For example, they want it in this format ![]() 100 --- 80 |
| Posted by hansmex at Apr 1, 2021, 8:02:50 PM |
Re: I got some Problems to set a Wall (Angles seems to be the problem?) You could add text in that format. It's not possible to do it automatically. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by lozdigloz at Apr 1, 2021, 9:25:09 PM |
Re: I got some Problems to set a Wall (Angles seems to be the problem?) thanks, so easy and I couldn't figure it out ... :D |
Current timezone is GMT Sep 24, 2026, 8:55:10 AM |
