Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Group of objects |
| Print at Jul 28, 2026, 11:32:55 PM | |
| Posted by crevetus at Sep 28, 2009, 12:08:55 AM |
Group of objects Hello, I like very much this program! It`s a very nice tool! I have a question: if I select a group of objects, how can i move the group in all 3 dimensions? I could only move the group bacward-forward or left-right but not up-down. Thanks! |
| Posted by Puybaret at Sep 28, 2009, 4:43:38 PM |
Re: Group of objects Grouping/ungrouping a set of objects should be available in the coming versions to help you move, resize and rotate a group of objects. Meanwhile, here are two workarounds: - you may select the objects you want to elevate and choose Furniture > Modify... menu item to change their elevation, but then, of course, all the selected objects will have the same elevation, - you may select these objects, copy paste them in a new home, export that document to OBJ format with 3D view > Export to OBJ format... menu item, import the exported OBJ file with Furniture > Import furniture... menu item, and move the imported group of objects. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Jul 28, 2026, 11:32:55 PM |
